RR501 receives the rf signal, but won't send to other units
Jun 17, 2005 6 Replies
Jump to replies (6)
Ihave a RR501 wieless transceiver and the palmpad combo. I plug the RR501 in, set to my house code 'I', unit 1 *or* set to unit 9 and set the palmpad to house code 'I', and when I press the appropriate on or off button for unit 1 or 9, I hear a click from the RR501, but none of the other X-10 units get their signal (i.e. if I want unit 1 on, I get nothing).
What am I missing?
Dave,
I am not sure I understand. My plug in X-10 controller works fine. Is there a possibility that the RF receiver is not working properly? I had one fail a couple of years ago and this is the replacement.
The relay is triggered by the RF signal but the RR501 must send via the powerline (PLC) to other units. It may be that you have PLC signal strength issues which can be caused by several things. See...
>Hi,
That's what I did. After I concluded that the RR501 was receiving the RF signal (as evidenced by the click when unit code 9 was sent), but that the X-10 signal wasn't going anywhere (as evidenced by units
1,2,3,4 or 9 not responding) I unplugged the %%501 and plugged in the table top transmitter to the same outlet. Viola! X-10 response.
Any further thoughts?
It's unlikely that the RF receiver isn't working since it must be working for the relay to respond.
The most likely causes are that the RR501 is plugged into a different phase than the plug in X-10 controller and your modules or that there is an appliance in the (electrical) vicinity of the RR501 that is eating X-10 PLC signals.
Move the RR501 to the same outlet as the plug >Dave,
Ahhh! Why didn't you say so in the first place? ;)
If the table top controller works in the same outlet, you've ruled out a signal sucking appliance.
It appears that your RR501 has indeed gone bad. The RF receiver section is probably OK since you can control the relay with it but the PLC transmitter section (which sends to the powerline) is kaput.
Just out of curiosity, try c>That's what I did. After I concluded that the RR501 was receiving the
I'm almost certain of whats happening, going by the symptoms and my very similiar experience; there is a small transformer near the 120V outlet that generates the outgoing 120 kHz, and also couples it to the mains.
You could confirm this by checking your unit against the schematic available at
Regards,
Anand Dhuru
My bet is the w> Ahhh! Why didn't you say so in the first place? ;)
