I have activehomepro... and an external motion sensor.. problems... help needed
Aug 06, 2006 1 Replies
I want to have my external black motion sensor only work when it is 8pm to 1130 pm. i set it to go off anytime it sees motion but set the macro to only work during the aforementioned hours thinking the macro would over ride the sensor but it doesnt work.. what do i do ? marv
I haven't tried to keep up with newer versions of the CM15A firmware/software but based on earlier releases...
The motion detector sends an RF signal which the CM15A will automatically send to the powerline as long as you have that housecode set to be "transceived".
