Zone Alarm 5.1.011
Aug 05, 2004 2 Replies
I just installed the new update for ZA pro yesterday and so far, everything seems to be OK. I had serious problems with the two previous versions, but this one seems stable and I don't have any problems with the internet as I did with the first two. I hope it keeps holding up. I was getting tired of going back to 4.5. As soon as my subscription is up though, I am going to try another firewall. Zone Labs is no longer dependable.
DDDD
Hi, I don't know why, but since I try ZA 5.0.011, I have port 135 & 1025 open. (small network with connection share) Don't know how to close them. I don't find the way to create a rule to close those port in Firewall >
Level setting > HIGH setting. It didn't do that with previous version. I'm tired to find a solution and return to 4.5. pascal
Sorry, error. Still the same problem with ZA 4.5 It seems that Zone alarm doesn't like the fonction "This computer is an ICS/NAT gateway". If you check on the others computer "This computer is a client of an ICS/NAT gateway running Zone Alarm", ports 135 and 1025 are Open. Pascal
