netscreen 5gt - dyndns
Apr 04, 2006 2 Replies
Hello,
i have a problem to configure my 5gt to works with dyndns.com services.
I have entered this configuration :
server type : dyndns server name: dyndns.org refresh interval : 1 min update interval : 1 clear text: x username: username passwoord: ***** agent : -blank- bind to interface ethernet3 (untrust) hostname: domainname.be&system=custom
I receive this error :
2006-04-04 17:51:35 notif Success response received for DDNS entry update for id 12 user "username" domain "domain.be&system=custom" server type "DYN" name "dyndns.org"
2006-04-04 17:51:35 notif DDNS server dyndns.org returned incorrect ip
0.0.0.0, local-ip should be 82.146.104.208
And off course the ip is not renewed.
thank you for your help
T
I have members.dyndns.org, but I don't think that's your problem.
These settings are liable to get you banned for abuse. I recommend:
refresh interval : 670 min update interval : 30
It's a good idea to download and install their certificate - otherwise someone might sniff your credentials.
^^^^^ What is that? The characters '&' and '=' are not valid in a domain name.
I'm guessing the dyndns server accepted your credentials...
... but rejected your domain name.
Triffid
Hello,
Thank you for your answer, I will try ... for "&system=custom" , I have received that from the dyndns support but it doesn't work (off course).
See u.
