Linksys BEFSR41 / RV082 VPN Connection
Apr 06, 2007 1 Replies
My company recently installed a Linksys RV082 to allow VPN connections into work. At home, I have a Linksys BEFSR41 3.1 router with firmware version 1.05. I cannot connect in to work if I connect in through the BEFS router (either wirelessly or hardwired). But, if I hardwire directly into the cable modem, I am able to connect. So it seems as if there is something on the BEFSR41 that needs to be configured so that it will allow the communication to occur. I've researched endlessly, but haven't been able to find anything that works. My laptop is running Win-XP Pro. Thank you in advance.
If there is a VPN page, then chk the "allow pass through" option , If not then maybe an update ?
Have you searched Linksys knowledgebase for your model and VPN ?
pjm snipped-for-privacy@msn.com wrote:
