BEFSR41 led behaviour on power-up
Aug 30, 2004 4 Replies
Jump to replies (4)
BEFSR41 led behaviour on power-up open original image
Hello:
I recently had a power surge take out my router (linksys BEFSR41 v2 Firmware Version 1.46) i was able to repair it, everything seems to work fine, but on power-up all leds light except the Act on the WAN column, i can't remember if it was like that before the surge. Could someone be so kind as to unplug and plug his/her unit and see if it behaves like mine?
Thanks in advance.
Steve Sousa
The LED is no indicator of performance. If you have a connection, go to
and run some speed tests. Satisfy yourself that the router is OK.
Q
Act flashes in synchronism with the activity led on my cable modem.
Hello:
I wasn't worried about performance(yet). It's just that the lighting of all led's on power up is kind of a self-diagnostic indication, and i wanted confirmation that the router thinks its ok.
Thanks
Steve
Having owned two of these Linksys routers, I guarantee that if it fails you will know it immediately.
Q
