i need help
Apr 14, 2007 8 Replies
Jump to replies (8)
dear all, i am a network admin in a company,currently i have to block all kind of messengers for all clinet pcs' i don't have a hard-ware firewall.can you tell me how to block these messengers...
ehm... deny everything until it's explicitly allowed? Implement this policy technically and in the work contract?
You could do soft routing on a server and have all traffic headed for the outside world go through that machine. By doing that you can control which ports are permitted.
Send a memo to all employees telling them that messengers are not allowed. Wait for a week, then go from machine to machine to search for installed messengers.
The first one you find, report the user to the HR department and have him admonished and/or fired for violating company policy.
Lather, rinse, repeat... after a few users are gone, people will get the message and respect the policy. You won't have many friends anymore, though ;-)
Juergen Nieveler
Please read the original posting again. He even hasn't got proper a device to block outgoing traffic with.
Well, IM software is known to be quite good at tunneling. Blocking messengers at the gateway can be a bit tricky.
Wolfgang
Who's talking about network filtering? You can impliment this policy on the clients by explicitly denying to execute any program except those on a whitelist. Bam, the user can't run the messenger software anymore.
As I told, the technical aspect should just backup the legal aspect.
Another option would be to do a quick estimate of how many hours each engineer spend on messenger every week (be very liberal in estimating this), multiply by average income of the engineers and make a point why investing in a firewall would be cheaper.
- Biswajit Bangalore/INDIA
create your own firewall. install iptables on a cheap server with 2 network interfaces. put it in the middle of your main WAN traffic stream. set up the proper rules.
alternatively, a modification on juergen's suggestion. go to every computer, remove every messenger program, make every user a normal user (not a local administrator), they won't be able to install any unauthorized software (this is best practice anyway).
alternatively, set up a GPO on the AD domain (if you're using Active Directory) to configure client's Windows Firewall rules to not allow messenger ports.
-Tony
