Fortinet/FortiGate - experience and observations?
Oct 24, 2006 6 Replies
www.BradReese.Com
You may wish to investigate the Miercom Competitve Lab Tests between the: Fortinet FortiGate 1000 vs. Cisco ASA 5520 Juniper Networks NetScreen-208 Checkpoint VPN-1 Pro Brad Reese - Cisco vs. Competitor Lab Tests Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803…
Fortinet/FortiGate - experience and observations? open original image
Fortinet and its FortiGate product line seem to have appeared out of nowhere since the last time I looked at the firewall market. Does anyone have any experience with their products (esp at the high end of the SMB line - say the 300a)? The trade press reviews seem to indicate that the FortiGates have reasonably high performance, provide good price/performance ratio, but are difficult to set up. Does that match your experience?
Specific features I am looking at are QoS and two-ISP load sharing.
Thanks.
sPh
vs.
Cisco ASA 5520
Sincerely,
Brad Reese BradReese.Com - Cisco vs. Competitor Lab Tests
Hello sphealey,
We use this at work. I even spent a day with Fortinet Europe yesterday... :)
I like the product. You can do much with it.
QoS; supported. But I haven't tried it much. What do you need?
Load-sharing: supported. I have customers running this today. You should have almost equal speed lines. The load is divided by connection, so you will get unequal load anyway.
Isn't it funny when a vendor is ordering a test that their product is always winning by far and zero fields of improvement?
Other similar readings may include:
and:
Good luck!
Lars
Hello
I'm very scpetic where reviews give 100% to the one vendor paying for the test.
I got a Fortigate-500 unit at work and I have better performance than you got from the bigger FG-1000 unit. I don't use the antispam and the webfiltering function. But you didn't test with these functions enabled.
I had a good experienced on Fortigate 200 I worked around 1 year on that UTm Device and now upgraded to Fortigate 300A with failover.
Its not true Fortigate works like same as all other but it architecture is chip based sop processing is fast and i used a smal box like 200 in
100 users enviornemnt with fully loaded Antivirus,AntiSpam,WebF, user based Bandwdth shaping etc. Pricing is just a bit low then other devices like Sonicwall, Watchguard etc.
Its little bit diffrent then other devices GUI based but its better to take Admin guide before setting up BOX.
For QOS you have to cnfigure it it does IP and user based QOS . For Load balancing make sure you take minimum 4 port BOX.
CK
sphealey wrote:
EdwardFerrara had written this in response to
: My experience with the AM60 is that yes it is difficult to setup. I also don't see alot of activity on this board for this type of device. Your post is over two years old. We'll see if someone responds.
Ed Ferrara __!__ -----o----- \\" \\"
------------------------------------- sphealey wrote:
##-----------------------------------------------## Delivered via
Internet Knowledge Base for the security industry no-spam access to your favorite newsgroup - comp.security.firewalls - 27635 messages and counting! ##-----------------------------------------------##
