Building a firewall
Jul 19, 2006 3 Replies
Jump to replies (3)
Building a firewall open original image
Hi, I'm not sure if this is in the scope of this newsgroup, so if it is not, can you tell me what newsgroup I should go to. Anyways, I would like to build a firewall in windows, and would like to know if there are any tutorials that you know of about making a firewall in C++
Firewall architecture defines two components - kernel component that works with other subsystems (C) - controlling software (configuration, commandline and communication) (C++)
Take a look at any opensource implementation.
To configure Windows' packet filter:
To implement your own filtering, you i.e. could start here:
If you're developing for Windows 2000 and Windows XP, you could read this:
If you're developing for Windows Vista, you could read this:
Yours, VB.
to add my two cents to Volker's informations; you may find some working code on sourceforge; for example the wipfw
is a windows port of the BSD ipfw stateful packet filter and engine to windows and it uses the native windows APIs, so it may be a good starting point another SF prj is
which, although not as "locked down" as wipfw (tdifw is a "simple" TDI level filter) may give you some more ideas
