Reading Watchguard Logs
Jul 19, 2006 5 Replies
Jump to replies (5)
Silly question....
I'm trying to analyze some of our logs and not sure what to make of the Proto heading.
Date Time Disp. i/f Proto.
07/30/01 11:17:23 deny in eth0 78 udp 20 128
I understand the 'udp' part, but what do the 78, 20 and 128 mean?
Thanks,
FGR
Which WG unit do you have?
My firebox units have a LOT more in the logs and the log viewer has a header that explains the columns.
My columns are as follows: Date Time Disp (deny/allow) Direction (in/out) I/F (interface ETH0:1, ETH0:2, ETH0, ETH1....) Protocol UDP, ICMP, TCP Source IP Dest IP Source Port Dest Port Details (rule that caused the action)
I am running a FB 1000 (or 3) I think I understand everything else, except the '78 udp 20 128' E.g. what does the 78 mean? same for the 20 and 128.
Thanks for the response!
FG
Leythos wrote:
Paste the entire line of the log entry, it appears you're missing something.
You're missing the source/dest IP values in what you've pasted and the "Details" value also.
All my UDP entries show a lot more detail than your.
My Firebox III/1000, II, x700, X1000, etc... all show a lot more detail than you've provided.
What version of the firmware and logging are you running?
The current version is 7.4x
Here it is:
06/21/06 10:12 firewalld[127]: deny in eth2 78 udp 20 128 192.168.0.78 192.168.0.255 137 137 (spoofed source address)
BTW - We are running v7.3.
Thanks!
Leythos wrote:
137 is from typical Windows crap, we always block ports 135 through 139 and 445 between interfaces.
The spoofed could be a couple things:
1) Is your internal network on 192.168.0.0/24? If not, then you've got a rogue NODE someplace in your network. 2) You didn't setup the blocked NAT Config to allow 192.168.0.0/24, default is to not approve 192.168.0.0/16 I think.
As for the 78, 20, 128, I don't know what they represent. When I check my logs I don't see things like that anywhere.
Consider posting to the WG WSF groups and asking them.
