Application Control
Oct 10, 2005 3 Replies
Jump to replies (3)
Hi, I'm setting up appliction control on my Sygate firewall, and I was wondering if there are any websites out there that tell me what ports, protocols etc to plug into my firewall.
Say, do Microsoft have a webpage that gives you all this information or would I have to ring/email them?
In this context it's just another way of saying to put or to use or to configure.
Jason
This will not work.
To "plug"? What do you mean with "plug"?
Yours, VB.
It depends on what you are looking for. Something useful may turn up in the following search, it's also possible that it may not
If you need help configuring a Sygate product then you should probably contact Sygate. They do seem to have a support forum
Jason
