WLC 2006
Jun 14, 2007 2 Replies
WLC 2006 open original image
Hi guys,
I have a WLC 2006, when i configure both WLC and LWAP on the same vlan, the AP joins, but when i configure the WLC connection to the switch as a trunk, the AP wont join anymore.
Any thoughts?
Regards, Andy.
~ Hi guys, ~ ~ I have a WLC 2006, when i configure both WLC and LWAP on the same ~ vlan, the AP joins, but when i configure the WLC connection to the ~ switch as a trunk, the AP wont join anymore. ~ ~ Any thoughts? ~ ~ Regards, ~ Andy.
If the AP and WLC are in different subnets, then a) AP needs a way to find out the IP address of its WLC, and b) AP needs layer 3 connectivity to the WLC
For a), some methods are:
- provide AP with its WLCs' IP addresses via DHCP option 43
- provide the WLCs' addresses in DNS via CISCO-LWAPP-CONTROLLER
another method is to use an IP helper address on the AP's default router.
More reading:
Wireless LAN Controller and Lightweight Access Point Basic Configuration Example
Lightweight AP (LAP) Registration to a Wireless LAN Controller (WLC)
Deploying Cisco 440X Series Wireless LAN Controller (90% of this is applicable to 2006)
Aaron
Aaron,
In this link:
If you look at the diagram, it shows that the AP is in Vlan 5, and the trunk of the WLC has this Vlan excluded.
Also, what about Vlan 3 and Vlan 4 on the WLC?
I am assuming that Vlan 60 is the native management Vlan.
Regards, Andy
