WLC 2006
Jun 01, 2007 6 Replies
Jump to replies (6)
Hi guys, I have a Cisco WLC 2006, with a male DB-9 serial port, i connected a gender changer (Female - Female) to be able to connect the WLC to my laptop using a male DB-9 serial to USB, but i can not connect through the terminal.
I also used a Female to female DB-9 serial cable to connect the WLC to the laptop male DB-9 but also dod not work.
Am i missing something here in the WLC serial pins?
I used the usual terminal settings:
9600 baud
8 data bits
1 stop bit
No parity
No hardware flow control
WLC 2006 open original image
Hi guys, i am having a problem with one of the 1200 LWAP to join the controler, i can ping the controler from the LWAP, but it is not joining.
The WLC IP address is 10.10.10.100, i pasted the log below.
********************************************************************************************** Sending 5, 100-byte ICMP Echos to 10.10.10.100, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms AP0011.21ee.1525#
*Mar 1 00:00:34.336: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
Mar 1 00:00:40.337: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not rec ieve the Join response
*Mar 1 00:00:40.337: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses remain.
*Mar 1 00:00:40.527: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Re ason: DID NOT GET JOIN RESPONSE.
Mar 1 00:00:40.527: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
Your help is higly appreciated Regards Andy
~ Hi guys, i am having a problem with one of the 1200 LWAP to join the ~ controler, i can ping the controler from the LWAP, but it is not ~ joining. ~ ~ The WLC IP address is 10.10.10.100, i pasted the log below. ~ ~ ~
********************************************************************************************** ~ Sending 5, 100-byte ICMP Echos to 10.10.10.100, timeout is 2 seconds: ~ !!!!! ~ Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms ~ AP0011.21ee.1525# ~ *Mar 1 00:00:34.336: %LWAPP-5-CHANGED: LWAPP changed state to JOIN ~ *Mar 1 00:00:40.337: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: ~ Did not rec ~ ieve the Join response ~ ~ *Mar 1 00:00:40.337: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP ~ addresses ~ remain. ~ ~ *Mar 1 00:00:40.527: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. ~ Reload Re ~ ason: DID NOT GET JOIN RESPONSE. ~ *Mar 1 00:00:40.527: %LWAPP-5-CHANGED: LWAPP changed state to DOWN ~ ~ ~ ********************************************************************************************************* ~ ~ ~ Your help is higly appreciated ~ Regards ~ Andy
Does the AP1200 have a MIC or an SSC? If the latter, has the SSC been installed in the WLC?
Here are some troubleshooting ideas:
Hth,
Aaron
Aaron,
Thank you for the document, i am working on it, and i will get back to you once it resolved or not.
Regards, Andy
I entered this command:
(Cisco Controller)>config auth-list add ssc 00:0e:84:32:04:f0 AP_Key
And the AP key you can get from the cvs file in the upgrade utility folder.
Regards, Andy
