PIX 506e FireWall and Cisco VPNClient 4.6
Apr 03, 2005 3 Replies
Jump to replies (3)
PIX 506e FireWall and Cisco VPNClient 4.6 open original image
All,
I am a newbie to the PIX firewalls. Currently now the PIX is just allowing Internet access.
We have users that would like to work remotely. I was thinking about doing a VPN from the firewall to their remote desktops using the Cisco VPN Cleint software.
Our setup is veyr simple:
Remote PC -> Cable Modem --> Internet --> Office ISP Managed Router ->
PIX 506 -> Internal Network
I have been looking on the Cisco site and have not found a document that can just simply tell me how to do it. It shouldn't be that difficult either. But I guess difficult enough for my lack of skillset.
Any information on how to configure the PIX and VPNClient pc would be helpful
Thank you in advanced.
You may find the Cisco Config Wizard helpful:
as well as Cisco PIX Configuration Examples and TechNotes:
Sincerely,
Brad Reese BradReese.Com=AE Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272 Website:
Sincerely,
Thanks Brad for your help. I am reviewing the links now. The first link, I do not know how to use that. Do you know how to use it?
The second link I am trying to find document which best suits my issue. I will keep you informed of how it goes.
Thanks again!
V
Hello Brad,
I tried the configuration within the document for a PIX-VPN3000 setup. I was able to connect via the VPN Client to the PIX. The client received an IP address. But I was not able to access any internal resources. :-((
Two questions:
1..One of the commands was to setup an access-list to allow NAT-ing for the internal network.
Why do I need this for?
  1. What else should I look at to get access to my internal resources, such as Email and File&Print shares.?
Any information would be appreciated.
Thanks!
