Trying to send call to Asterisk
Jul 03, 2005 0 Replies
Hello:
My AS-5300 is configured properly and switching calls to a hardware (Dialogic) IVR.
Now, I would like to start experimenting with a software IVR based on Asterisk, which I installed in a Linux server.
What I would like is to find out whether I have the correct dial peer configurations. They look like this:
!Inbound Dial Peer: ! dial-peer voice 874 pots incoming called-number ^7224$ direct-inward-dial port 2:D ! an ISDN PRI is conected here !
! Outbound Dial Peer: dial-peer voice 7224 voip destination-pattern ^7224$ session target dns:asterisk-server.domain.com !
When I place a call into the number (xxx) xxx-7224 it is received by the Cisco but it is rejected immediately with a "Destination out of order" Q931 error message.
The "show dialplan number 7224" command looks fine, and I assume the Cisco is configured Ok. However, it looks as if the Cisco is not even trying to establish a TCP/IP session with the asterisk-server host (according to tcpdump).
Any tips or suggestions are much appreciated.
-Ramon F Herrera
