No ringback in VoIP call
Aug 01, 2005 1 Replies
I have an AS-5300 which receives calls though a POTS PRI and sends them out as VoIP to my SIP home phone (see config below). The problem is that the caller doesn't get to hear any ringbacks as the call proceeds. I, on the other hand, hear my SIP phone ringing loud and clear.
In the past, I solved a very similar problem by adding this line to the corresponding dial peer:
progress_ind alert enable 8
but that was a pots dial peer. The trick doesn't seem to work with a voip dial peer.
Any tips are much appreciated.
-Ramon F Herrera
dial-peer voice 7224 voip destination-pattern ^684485$ session protocol sipv2 session target ipv4:24.147.123.5:5060 session transport udp dtmf-relay rtp-nte codec g711ulaw
I found a solution. Just add this to the vopi dial peer:
tone ringback alert-no-PI
-Ramon
