ISDN Wont Accept and Transfer PSTN Calls To CCM "bad bearercap" (AS5350-CCM)
Jan 28, 2005 2 Replies
anonyme wrote in news:41fa209c$0$20494 $ snipped-for-privacy@read.news.fr.uu.net:
You're receiving calls with bearer capability data, but expecting only voice?
AS5350 Version 12.3(11)T2
I want to Transfer Calls From ISDN to CCM , The transfer call from PSTN to CCM doesn't work. When I try I have a busy line.
I try this command on interface Serial3/0:15 "isdn incoming-voice Voice", but "voice" done % Invalid input detected
This is my config : ===================
version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname AS5350 ! boot-start-marker boot system flash c5350-is-mz.123-11.T2.bin no boot startup-test boot-end-marker ! enable secret enable password ! resource-pool disable calltracker enable calltracker history max-size 30 calltracker call-record verbose spe default-firmware spe-firmware-1 no voice-fastpath enable no aaa new-model ip subnet-zero ! ip cef isdn switch-type primary-net5 isdn logging ! voice service voip fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco cause-code legacy h323 call start slow ! fax interface-type fax-mail ! controller E1 3/0 framing NO-CRC4 pri-group timeslots 1-16 ! interface Serial3/0:15 no ip address isdn switch-type primary-net5 isdn send-alerting isdn sending-complete no cdp enable ! ip classless ip route 0.0.0.0 0.0.0.0 192.168.30.20 no ip http server ! map-class dialer test dialer voice-call ! control-plane ! voice-port 3/0:D bearer-cap 3100Hz ! voice-port 3/1:D ! no mgcp timer receive-rtcp no mgcp explicit hookstate ! dial-peer voice 3000 voip destination-pattern T session target ipv4:192.168.30.205 incoming called-number 9762 dtmf-relay h245-alphanumeric codec g711ulaw ! dial-peer voice 1 pots destination-pattern 0T direct-inward-dial port 3/0:D ! ss7 mtp2-variant Bellcore 0 ss7 mtp2-variant Bellcore 1 ss7 mtp2-variant Bellcore 2 ss7 mtp2-variant Bellcore 3 ! line con 0 line aux 0 line vty 0 4 password xxx login line 1/00 1/59 no flush-at-activation modem InOut ! scheduler allocate 10000 400 ntp clock-period 17180058 ntp server 64.112.189.11 end
The debug and the error : ========================= AS5350#sh debug
The following ISDN debugs are enabled on all DSLs:
debug isdn error is ON. debug isdn event is ON. debug isdn q931 is ON. (filter is OFF) debug isdn silent errors is ON.
AS5350#
*Jan 1 18:13:24.376: ISDN Se3/0:15 Q931: RX RELEASE_COMP pd = 8 callref = 0x8014 Cause i = 0x80D8 - Incompatible destination
Hi Andreas,
Yes, for the moment I want only receive voice call
Thanks in advance
