cisco 1721 triangle whit 2 cisco 800 over isdn 128k
Jun 23, 2005 4 Replies
Jump to replies (4)
Hi guys,
Im having issue whit my litle configuration, we got 3 router on 3 different subnet that are link together via a ISDN 128k for each (64k per spid), one is working very well no problem at all, bu the second whit same config exept hes on a second subnet, DNS query wont go through anymore, ping loosing packet, hudge delay when using network etc ...
I've called the provider for testing purpose and all seem to be working on their side !
show interface :
BRI0 is up, line protocol is up (spoofing) Hardware is PQUICC BRI with U interface (Infenion) Internet address is 192.168.254.1/24 MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, loopback not set Last input 00:00:09, output never, output hang never Last clearing of "show interface" counters 42w1d Input queue: 0/75/132/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 48 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 1925505 packets input, 8744259 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 132 input errors, 132 CRC, 0 frame, 0 overrun, 0 ignored, 205 abort 2144641 packets output, 10383595 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 output buffer failures, 0 output buffers swapped out 15 carrier transitions BRI0:1 is up, line protocol is up Hardware is PQUICC BRI with U interface (Infenion) MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Open, multilink Open, loopback not set Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 18174 Queueing strategy: weighted fair [suspended, using FIFO] FIFO output queue 0/40, 18174 drops 5 minute input rate 0 bits/sec, 1 packets/sec 5 minute output rate 0 bits/sec, 1 packets/sec 70980133 packets input, 2393550652 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 71423688 packets output, 2846385016 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 3846 carrier transitions BRI0:2 is up, line protocol is up Hardware is PQUICC BRI with U interface (Infenion) MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 3/255, rxload 3/255 Encapsulation PPP, LCP Open, multilink Open, loopback not set Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair [suspended, using FIFO] FIFO output queue 0/40, 0 drops 5 minute input rate 1000 bits/sec, 2 packets/sec 5 minute output rate 1000 bits/sec, 2 packets/sec 3792565 packets input, 521615281 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 2438815 packets output, 251686116 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 21 carrier transitions BRI1 is up, line protocol is up (spoofing) Hardware is PQUICC BRI with U interface (Infenion) Internet address is 192.168.254.4/24 MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, loopback not set Last input 00:00:00, output never, output hang never Last clearing of "show interface" counters 42w1d Input queue: 0/75/1831/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 48 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 1958052 packets input, 8959287 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 1831 input errors, 1811 CRC, 0 frame, 0 overrun, 0 ignored, 1225 abort 2209675 packets output, 10905849 bytes, 0 underruns 0 output errors, 0 collisions, 3 interface resets 0 output buffer failures, 0 output buffers swapped out 35 carrier transitions BRI1:1 is up, line protocol is up Hardware is PQUICC BRI with U interface (Infenion) MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 7/255, rxload 1/255 Encapsulation PPP, LCP Open, multilink Open, loopback not set Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 5963 Queueing strategy: weighted fair [suspended, using FIFO] FIFO output queue 0/40, 5963 drops 5 minute input rate 0 bits/sec, 2 packets/sec 5 minute output rate 2000 bits/sec, 2 packets/sec 66039007 packets input, 1735592307 bytes, 0 no buffer Received 0 broadcasts, 5 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 66300329 packets output, 247124329 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 4084 carrier transitions BRI1:2 is up, line protocol is up Hardware is PQUICC BRI with U interface (Infenion) MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 7/255, rxload 1/255 Encapsulation PPP, LCP Open, multilink Open, loopback not set Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair [suspended, using FIFO] FIFO output queue 0/40, 0 drops 5 minute input rate 0 bits/sec, 2 packets/sec 5 minute output rate 2000 bits/sec, 2 packets/sec 1137135 packets input, 78615116 bytes, 0 no buffer Received 0 broadcasts, 6 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 1544961 packets output, 298643438 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 303 carrier transitions FastEthernet0 is up, line protocol is up Hardware is PQUICC_FEC, address is 000f.9067.4387 (bia 000f.9067.4387) Internet address is 192.9.200.2/24 MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Half-duplex, 10Mb/s, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 7000 bits/sec, 10 packets/sec 5 minute output rate 6000 bits/sec, 10 packets/sec 161846504 packets input, 426870115 bytes Received 24950665 broadcasts, 0 runts, 0 giants, 0 throttles 15 input errors, 1 CRC, 12 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 141284804 packets output, 3941750882 bytes, 0 underruns 490 output errors, 736296 collisions, 20 interface resets 0 babbles, 19 late collision, 458368 deferred 169 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Virtual-Access1 is up, line protocol is up Hardware is Virtual Access interface MTU 1500 bytes, BW 128 Kbit, DLY 100000 usec, reliability 255/255, txload 9/255, rxload 3/255 Encapsulation PPP, LCP Open, multilink Open Open: CDPCP, IPCP MLP Bundle vaccess, cloned from BRI1 Vaccess status 0x40, loopback not set DTR is pulsed for 5 seconds on reset idle 00:01:59 Last input 00:00:56, output never, output hang never Last clearing of "show interface" counters 1d10h Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/14/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 96 kilobits/sec 5 minute input rate 2000 bits/sec, 6 packets/sec 5 minute output rate 5000 bits/sec, 5 packets/sec 449228 packets input, 33642557 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 452461 packets output, 134032764 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions Virtual-Access2 is up, line protocol is up Hardware is Virtual Access interface MTU 1500 bytes, BW 128 Kbit, DLY 100000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Open, multilink Open Open: CDPCP, IPCP MLP Bundle vaccess, cloned from BRI0 Vaccess status 0x40, loopback not set DTR is pulsed for 5 seconds on reset idle 00:01:59 Last input 00:00:12, output never, output hang never Last clearing of "show interface" counters 6d21h Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/5/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 96 kilobits/sec 5 minute input rate 0 bits/sec, 2 packets/sec 5 minute output rate 1000 bits/sec, 2 packets/sec 2066110 packets input, 745881122 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 1848519 packets output, 236006957 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions
If you guys got any ideas of what could i do to fix that !
Thanks in advance !
Thanks in advance !
For the 1721:
Using 1771 out of 29688 bytes ! version 12.3 service config service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname polyform ! boot-start-marker boot-end-marker ! enable secret 5 $1$cgUn$ZfAxEfC6d/D5/VoNW3mXh/ enable password xxx ! username polytech password 0 maiubrccpf username polymax password 0 maiubrccpf mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 no aaa new-model ip subnet-zero ip cef ! ! ! no ftp-server write-enable isdn switch-type basic-ni ! ! ! ! interface BRI0 ip address 192.168.254.1 255.255.255.0 encapsulation ppp dialer map ip 192.168.254.2 name polytech broadcast 93780999 dialer map ip 192.168.254.2 name polytech broadcast 93781080 dialer load-threshold 1 outbound dialer-group 1 isdn switch-type basic-ni isdn spid1 450378081400 3780814 isdn spid2 450378084000 3780840 ppp authentication chap ppp multilink ! interface BRI1 ip address 192.168.254.4 255.255.255.0 encapsulation ppp dialer map ip 192.168.254.3 name polymax broadcast 93781236 dialer map ip 192.168.254.3 name polymax broadcast 93781244 dialer load-threshold 1 outbound dialer-group 1 isdn switch-type basic-ni isdn spid1 450378721000 3787210 isdn spid2 450378524400 3785244 ppp authentication chap ppp multilink ! interface FastEthernet0 ip address 192.9.200.2 255.255.255.0 speed auto half-duplex no cdp enable ! ip classless ip route 0.0.0.0 0.0.0.0 192.9.200.252 ip route 192.168.1.0 255.255.255.0 192.168.254.2 ip route 192.168.2.0 255.255.255.0 192.168.254.3 no ip http server ! dialer-list 1 protocol ip permit snmp-server community public RO snmp-server enable traps tty ! line con 0 exec-timeout 0 0 password maxon login line aux 0 line vty 0 4 password maxon login ! ! end
For first cisco 800 :
Using 1102 out of 8077 bytes ! version 12.1 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname polymax ! no logging buffered enable password 7 031454071F0220540F ! username polyform password 7 0009120F115919050C314A ! ! ! ! ! ! ip subnet-zero ! isdn switch-type basic-ni ! ! ! interface Ethernet0 ip address 192.168.2.254 255.255.255.0 ip helper-address 192.9.200.35 ip directed-broadcast ! interface BRI0 ip address 192.168.254.3 255.255.255.0 ip directed-broadcast encapsulation ppp dialer idle-timeout 999999 dialer map ip 192.168.254.4 name polyform broadcast 93787210 dialer map ip 192.168.254.4 name polyform broadcast 93785244 dialer load-threshold 1 outbound dialer-group 1 isdn switch-type basic-ni isdn spid1 450378123600 3781236 isdn spid2 450378124400 3781244 ppp authentication chap ppp multilink ! no ip http server ip classless ip route 0.0.0.0 0.0.0.0 192.168.254.4 ! dialer-list 1 protocol ip permit ! line con 0 password 7 011E071C5405 login transport input none stopbits 1 line vty 0 4 password 7 070220544107 login ! ! end
For the second 800
Using 1041 out of 8064 bytes ! version 12.0 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname polytech ! enable password xxx ! username polyform password 7 0009120F115919050C314A ! ip subnet-zero ! isdn switch-type basic-ni ! ! ! interface Ethernet0 ip address 192.168.1.254 255.255.255.0 ip helper-address 192.9.200.35 ip directed-broadcast ! interface BRI0 ip address 192.168.254.2 255.255.255.0 ip directed-broadcast encapsulation ppp dialer idle-timeout 999999 dialer map ip 192.168.254.1 name polyform broadcast 93780814 dialer map ip 192.168.254.1 name polyform broadcast 93780840 dialer load-threshold 1 outbound dialer-group 1 isdn switch-type basic-ni isdn spid1 450378099900 3780999 isdn spid2 450378108000 3781080 ppp authentication chap ppp multilink hold-queue 75 in ! ip classless ip route 0.0.0.0 0.0.0.0 192.168.254.1 ! dialer-list 1 protocol ip permit ! line con 0 password maxon login transport input none stopbits 1 line vty 0 4 password maxon login ! end
