Slow Point to Point T1 Access Please Help
Mar 14, 2007 7 Replies
Jump to replies (7)
Hello,
We have a point to point T1 line going between our main office and a branch, and the connection is very slow, I pasted the configurations below of both routers. At the branch location we have 15 workstations accessing the database over the T1 line, at our corp. office. The database is by advantage (sybase now) and I believe it utilizes mostly UDP for connections, it's a dos application that is installed locally on each system and then connects to the database in the corporate server. We have another 4 branches that have the same configs but most of them have 10 workstations. I'm new to cisco and the guy who configured the routers is not here anymore can you please take a look and make any suggestions on how to make it work faster. Also under available bandwidth it doesn't show the full 1.5 it shows 1.1 I believe is that normal? I appreciate any help, thanks a lot in advance! ###########Simi Valley Config#################
**Running Config***** Building configuration...
Current configuration : 3281 bytes ! version 12.4 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname simi ! boot-start-marker boot-end-marker ! security authentication failure rate 10 log security passwords min-length 6 logging buffered 4096 debugging logging console critical enable secret 5 $1$z2Yg$4oeDvCfJEks6S9gZm9VT6. enable password 7 04095E555A22485D ! aaa new-model ! ! aaa authentication login local_auth local ! aaa session-id common ! resource policy ! mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ip subnet-zero no ip source-route no ip gratuitous-arps ip cef ! ! no ip dhcp use vrf connected ! ip dhcp pool SIMI network 10.6.0.0 255.255.0.0 netbios-name-server 10.3.0.254 default-router 10.6.0.1 ! ! no ip bootp server no ip domain lookup ip domain name yourdomain.com login block-for 1 attempts 100 within 100 ! username cisco privilege 15 secret 5 $1$ZMSn$9/qJDaP00Ox8L8pvUknNs/ ! ! ! interface FastEthernet0/0 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$ ip address 10.6.0.1 255.255.0.0 no ip redirects no ip unreachables no ip proxy-arp ip nat inside speed auto full-duplex no mop enabled ! interface FastEthernet0/1 no ip address no ip redirects no ip unreachables no ip proxy-arp shutdown duplex auto speed auto no mop enabled ! interface Serial0/0/0 ip address 192.168.1.111 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp encapsulation ppp ! ip classless ip route 0.0.0.0 0.0.0.0 Serial0/0/0 ip route 10.3.0.0 255.255.0.0 192.168.1.100 ip route 10.3.0.251 255.255.255.255 10.3.0.1 ! no ip http server ip http authentication local ip http timeout-policy idle 5 life 86400 requests 10000 ip nat inside source list 1 interface FastEthernet0/0 overload ! ! logging trap debugging logging facility local2 snmp-server community public RO no cdp run
****Version***** Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SO FTWARE (fc1) Technical Support:
(c) 1986-2005 by Cisco Systems, Inc. Compiled Tue 25-Oct-05 17:10 by evmiller
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
simi uptime is 4 weeks, 3 days, 5 hours, 55 minutes System returned to ROM by power-on System image file is "flash:c1841-ipbase-mz.124-1c.bin"
Cisco 1841 (revision 5.0) with 114688K/16384K bytes of memory. Processor board ID FTX0947Z2BA
2 FastEthernet interfaces
1 Serial interface WIC T1-DSU DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2102
simi#
********Serial Info********** simi#show int s0/0/0 Serial0/0/0 is up, line protocol is up Hardware is GT96K with integrated T1 CSU/DSU Internet address is 192.168.1.111/24 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 2/255 Encapsulation PPP, LCP Open Open: IPCP, loopback not set Keepalive set (10 sec) Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 4w3d Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
2 Queueing strategy: weighted fair Output queue: 0/1000/64/2 (size/max total/threshold/drops) Conversations 0/74/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1158 kilobits/sec 5 minute input rate 17000 bits/sec, 9 packets/sec 5 minute output rate 7000 bits/sec, 7 packets/sec 33533354 packets input, 767112182 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 8 input errors, 8 CRC, 3 frame, 2 overrun, 0 ignored, 2 abort 27080721 packets output, 3552844864 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 1 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
simi#
###########Hollywood################
CORP2#sh run Building configuration...
Current configuration : 756 bytes ! version 12.2 service timestamps debug datetime msec localtime service timestamps log datetime msec localtime no service password-encryption ! hostname CORP2 ! logging buffered 4096 debugging no logging console enable secret 5 $1$EDuu$r.fjbiCbSabnjwqbFWnKN1 enable password 4123mka ! ip subnet-zero ! ! ! ! ! ! interface Ethernet0/0 ip address 10.3.0.2 255.255.0.0 full-duplex ! interface Serial0/0 ip address 192.168.1.110 255.255.255.0 encapsulation ppp ! ip classless ip route 0.0.0.0 0.0.0.0 10.3.0.1 ip route 10.1.0.0 255.255.0.0 10.3.0.1 ip route 10.2.0.0 255.255.0.0 10.3.0.1 ip route 10.4.0.0 255.255.0.0 10.3.0.1 ip route 10.6.0.0 255.255.0.0 Serial0/0 no ip http server ! !
*******Version************* CORP2#sh ver Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-I-M), Version 12.2(26), RELEASE SOFTWARE (fc2) Copyright (c) 1986-2004 by cisco Systems, Inc. Compiled Sat 31-Jul-04 04:57 by eaarmas Image text-base: 0x8000808C, data-base: 0x80A1E540
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
CORP2 uptime is 11 weeks, 5 days, 1 hour, 39 minutes System returned to ROM by power-on System image file is "flash:c2600-i-mz.122-26.bin"
cisco 2610 (MPC860) processor (revision 0x203) with 28672K/4096K bytes of memory . Processor board ID JAD05060ZK0 (1117921095) M860 processor: part number 0, mask 49 Bridging software. X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
************Serial Info********** CORP2#sh int s0/0 Serial0/0 is up, line protocol is up Hardware is PQUICC with Fractional T1 CSU/DSU Internet address is 192.168.1.110/24 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) LCP Open Listen: CDPCP Open: IPCP Last input 00:01:07, output 00:00:00, output hang never Last clearing of "show interface" counters 11w5d Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
1964 Queueing strategy: weighted fair Output queue: 0/1000/64/1963 (size/max total/threshold/drops) Conversations 0/60/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1158 kilobits/sec 5 minute input rate 2000 bits/sec, 2 packets/sec 5 minute output rate 11000 bits/sec, 2 packets/sec 64134072 packets input, 4142044605 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 7 giants, 0 throttles 44542 input errors, 1703 CRC, 20354 frame, 0 overrun, 0 ignored,
22485 abor t 82315917 packets output, 1641942282 bytes, 0 underruns 0 output errors, 0 collisions, 28 interface resets 0 output buffer failures, 0 output buffers swapped out 8 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
Can you clear the counters of the serial ports of both routers wait 30 minutes and copy another sh int serial for both?
Corp2's T1 is dirty as hell. Telco problem.
Just cleared the counters, will repot the stats in 30 min. Thanks for the reply!
Thank you for the reply, do you think it coud be wic card itself? or how can we tell that it's telco's problem, because this line is brand new and when they installed it they tested it and it was fine. Thanks
Here's the output for Corp. Router CORP2#sh int s0/0 Serial0/0 is up, line protocol is up Hardware is PQUICC with Fractional T1 CSU/DSU Internet address is 192.168.1.110/24 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) LCP Open Listen: CDPCP Open: IPCP Last input 00:00:23, output 00:00:00, output hang never Last clearing of "show interface" counters 00:43:32 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/60/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1158 kilobits/sec 5 minute input rate 3000 bits/sec, 3 packets/sec 5 minute output rate 4000 bits/sec, 4 packets/sec 31522 packets input, 3729718 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 37823 packets output, 12721725 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
Here's the output of the branch simi#sh int s0/0/0 Serial0/0/0 is up, line protocol is up Hardware is GT96K with integrated T1 CSU/DSU Internet address is 192.168.1.111/24 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Open Open: IPCP, loopback not set Keepalive set (10 sec) Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 00:43:28 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/74/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1158 kilobits/sec 5 minute input rate 7000 bits/sec, 7 packets/sec 5 minute output rate 6000 bits/sec, 7 packets/sec 36687 packets input, 11693618 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 30593 packets output, 3632418 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
simi#
I also took a look at the 2nd router that connects 3 other branches, 1 serial didn't have any errors or aborts, but the other 2 had a lot of them, is it the WIC cards going bad or a line problem?
Was the "show interface" snapshots taken when people were actually trying to access the database? -- it's utilization is near zero. Also, it would help to know the topology.
It would appear from the configurations you sent that there is more than one corporate router. If this is true, how is the database server configured to send traffic back to "simi." At first glance, I'm guessing there might be some ICMP redirects happening -- but you need to provide a complete "picture" of your network. (you might want to remove the password and community strings as well before posting)
-JC
What's the Round trip delay of the circuit when you ping from the routers to the IP on the serial port of the remote end?
