Tuning ADSL lines on Cisco's roputer.
Sep 05, 2005 7 Replies
Jump to replies (7)
Hi all,
I've been replacing telco's routers with a lot of 837. I have no problems setting them up for connectivity. What is getting me crazy is that telco's routers provide more speed rather than Cisco's ones. I can guess telco's ones coming from different vendors (Dlink, Roper, Comtrend) automatically set up themselves for best performance (once given basic parameters like VPI/VCI - username and password - eventually IP address). So could you have an idea how to test the configuration on 837?. I heard about different ways to do that, and I have mine in mind (like using growing ping size to set MTU on Ethernet interface [perhaps], or to see if there are dropped packets), but variables are so many and so hidden to me that I don't know where to begin.
Any help will be really appreciated.
Alex.
speed duplex issues ?
where to begin.
can you send me the configuration to check it for you
m.ammoura
mmmmhh.... you could be right. How to test that? Perhaps "sh int fa1" to see if there are packets dropped?
Thanks Alex.
Thanks Ammoura,
but all the configuration file contains critical information. Anyway I would know a method, even if I know that a glance to the all config could reveale the problem.
Alex.
post the output of the show interface command
Martin Bilgrav wrote:
Here it is... it is quite long. I can see no special problems. Following there is the config Keep in mind I took a snapshot when the LAN was unloaded and perhaps there are not so useful informations to do troubleshooting.
Thanks a lot,
Alex
Router#sh int FastEthernet1 is down, line protocol is down Hardware is FastEthernet, address is 0000.0000.0000 (bia 0000.0000.0000) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto Speed, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/0 (size/max) 5 minute input rate 0 bits/sec, 16 packets/sec 5 minute output rate 0 bits/sec, 21 packets/sec 7275 packets input, 0 bytes Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 8913 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet2 is up, line protocol is up Hardware is FastEthernet, address is 0000.0000.0000 (bia 0000.0000.0000) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/0 (size/max) 5 minute input rate 0 bits/sec, 47 packets/sec 5 minute output rate 0 bits/sec, 43 packets/sec 16674 packets input, 0 bytes Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 15510 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet3 is down, line protocol is down Hardware is FastEthernet, address is 0000.0000.0000 (bia 0000.0000.0000) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto Speed, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/0 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet4 is down, line protocol is down Hardware is FastEthernet, address is 0000.0000.0000 (bia 0000.0000.0000) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto Speed, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/0 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Ethernet0 is up, line protocol is up Hardware is PQUICC Ethernet, address is 0011.bbbd.8b5b (bia 0011.bbbd.8b5b) Internet address is 10.133.0.222/27 MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 10Mb/s ARP type: ARPA, ARP Timeout 04:00:00 Last input 06:11:38, output 00:00:03, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/100 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 23608 packets input, 4490288 bytes, 0 no buffer Received 264 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 86450 packets output, 23593330 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out ATM0 is up, line protocol is up Hardware is PQUICC_SAR (with Alcatel ADSL Module) MTU 1500 bytes, sub MTU 1500, BW 128 Kbit, DLY 80 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ATM, loopback not set Encapsulation(s): AAL5 AAL2, PVC mode 10 maximum active VCs, 1024 VCs per VP, 1 current VCCs VC Auto Creation Disabled. VC idle disconnect time: 300 seconds Last input never, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/224/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: Per VC Queueing 5 minute input rate 0 bits/sec, 1 packets/sec 5 minute output rate 0 bits/sec, 1 packets/sec 116220 packets input, 23988974 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 164100 packets output, 16555332 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 output buffer failures, 0 output buffers swapped out Ethernet2 is administratively down, line protocol is down Hardware is PQUICC Ethernet, address is 0011.bbbd.8b5b (bia 0011.bbbd.8b5b) MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 10Mb/s ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/100 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out NVI0 is up, line protocol is up Hardware is NVI MTU 1514 bytes, BW 10000000 Kbit, DLY 0 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation UNKNOWN, loopback not set Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out Dialer0 is up, line protocol is up (spoofing) Hardware is Unknown Internet address is XXX.XXX.XXX.XXX/32 MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) DTR is pulsed for 1 seconds on reset Interface is bound to Vi2 Last input never, output never, output hang never Last clearing of "show interface" counters 1w0d Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/0/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 42 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 116220 packets input, 23989692 bytes 164105 packets output, 16559424 bytes Bound to: Virtual-Access2 is up, line protocol is up Hardware is Virtual Access interface MTU 1500 bytes, BW 320 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Open Open: IPCP PPPoATM vaccess, cloned from Dialer0 Vaccess status 0x44 Bound to ATM0 VCD: 1, VPI: 8, VCI: 35, loopback not set Keepalive set (10 sec) DTR is pulsed for 5 seconds on reset Interface is bound to Di0 (Encapsulation PPP) Last input 00:00:00, output never, output hang never Last clearing of "show interface" counters 1w0d Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 1000 bits/sec, 2 packets/sec 5 minute output rate 1000 bits/sec, 2 packets/sec 116235 packets input, 23990176 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 164119 packets output, 16561022 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions Virtual-Access1 is up, line protocol is up Hardware is Virtual Access interface MTU 1500 bytes, BW 100000 Kbit, DLY 100000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Closed Base PPPoATM vaccess Vaccess status 0x40, loopback not set DTR is pulsed for 5 seconds on reset Last input never, output never, output hang never Last clearing of "show interface" counters 1w0d Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions Virtual-Access2 is up, line protocol is up Hardware is Virtual Access interface MTU 1500 bytes, BW 320 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Open Open: IPCP PPPoATM vaccess, cloned from Dialer0 Vaccess status 0x44 Bound to ATM0 VCD: 1, VPI: 8, VCI: 35, loopback not set Keepalive set (10 sec) DTR is pulsed for 5 seconds on reset Interface is bound to Di0 (Encapsulation PPP) Last input 00:00:00, output never, output hang never Last clearing of "show interface" counters 1w0d Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 1000 bits/sec, 2 packets/sec 5 minute output rate 1000 bits/sec, 2 packets/sec 116243 packets input, 23990824 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 164131 packets output, 16563962 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions
! version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname Router ! boot-start-marker boot-end-marker ! memory-size iomem 5 no logging console enable secret 5 $XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXxx ! no aaa new-model ! resource policy ! clock timezone CET 1 clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00 ip subnet-zero ! ! no ip dhcp use vrf connected ip dhcp excluded-address 10.65.2.193 10.65.2.196 ip dhcp excluded-address 10.65.2.217 10.65.2.222 ! ip dhcp pool DHCPPoolLAN_0 network 10.65.2.192 255.255.255.224 default-router 10.65.2.222 dns-server 192.168.38.31 192.168.38.19 XXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXX ! ! ip cef ip domain name italtbs.com ip name-server XXXXXXXXXXXXXXXxxx ip name-server XXXXXXXXXXXXXXXxx ip inspect name ethernetin http timeout 3600 ip inspect name ethernetin esmtp timeout 3600 ip inspect name ethernetin tcp timeout 3600 ip inspect name ethernetin cuseeme timeout 3600 ip inspect name ethernetin ftp timeout 3600 ip inspect name ethernetin h323 timeout 3600 ip inspect name ethernetin rcmd timeout 3600 ip inspect name ethernetin realaudio timeout 3600 ip inspect name ethernetin sqlnet timeout 3600 ip inspect name ethernetin streamworks timeout 3600 ip inspect name ethernetin tftp timeout 30 ip inspect name ethernetin udp timeout 15 ip inspect name ethernetin vdolive timeout 3600 no ip ips deny-action ips-interface ip ssh authentication-retries 5 ip ssh version 2 ! ! ! username XXXXXXXXXXXXxx password 7 XXXXXXXXXXXXXXXXXXXXXXx username CCCCCCCCCCCCCCCCCCCCCCCCCCCc password 7 CCCCCCCCCCCCCCCCCCCCCCCCC ! ! ! crypto isakmp policy 10 encr 3des hash md5 authentication pre-share group 2 lifetime 1200 crypto isakmp key XXXXXXXXXXXXXXXXXXXXXX address XXXXXXXXXXXXXXXXXXXXX crypto isakmp invalid-spi-recovery ! crypto ipsec security-association lifetime seconds 28000 ! crypto ipsec transform-set headquarter esp-3des esp-md5-hmac ! crypto map vpn2hq 10 ipsec-isakmp set peer XXXXXXXXXXXXXXXXXXXX set transform-set headquarter set pfs group2 match address 130 ! ! ! interface Ethernet0 ip address 10.65.2.222 255.255.255.224 ip nat inside ip inspect ethernetin in ip virtual-reassembly ip tcp adjust-mss 1452 no cdp enable hold-queue 100 out ! interface Ethernet2 no ip address shutdown hold-queue 100 out ! interface ATM0 no ip address no atm ilmi-keepalive bundle-enable dsl operating-mode auto hold-queue 224 in pvc 8/35 ubr 320 encapsulation aal5mux ppp dialer dialer pool-member 1 ! ! interface FastEthernet1 duplex auto speed auto ! interface FastEthernet2 duplex auto speed auto ! interface FastEthernet3 duplex auto speed auto ! interface FastEthernet4 duplex auto speed auto ! interface Dialer0 ip address negotiated ip mtu 1492 ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 no cdp enable ppp authentication chap pap callin ppp chap hostname XXXXXXXXXXXXXXXXXx ppp chap password 7 XXXXXXXXXXXXXx ppp pap sent-username XXXXXXXXXXXXX password 7 XXXXXXXXXXXXXXX crypto map vpn2hq ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 ip route 192.168.38.0 255.255.255.0 Dialer0 ! no ip http server no ip http secure-server ! ip nat translation max-entries 2000 ip nat inside source route-map vpn_2hq interface Dialer0 overload ! ! ip access-list extended vty-access permit tcp 10.65.2.192 0.0.0.31 any eq 22 permit tcp 10.65.2.192 0.0.0.31 any eq telnet permit tcp 192.168.38.0 0.0.0.255 any eq 22 permit tcp 192.168.38.0 0.0.0.255 any eq telnet deny ip any any access-list 130 permit ip 10.65.2.192 0.0.0.31 192.168.38.0 0.0.0.255 access-list 131 deny ip 10.65.2.192 0.0.0.31 192.168.38.0 0.0.0.255 access-list 131 permit ip 10.65.2.192 0.0.0.31 any snmp-server chassis-id DDDDDDDDDDDDDDDDDDDDD no cdp run ! route-map vpn_2hq permit 10 match ip address 131 ! ! control-plane ! ! line con 0 exec-timeout 120 0 no modem enable stopbits 1 line aux 0 line vty 0 4 access-class vty-access in exec-timeout 120 0 login local length 0 ! scheduler max-task-time 5000 end
0000.0000.0000)
looks fine ... no errors and no drops for how long has this unit been up ?
0011.bbbd.8b5b)
looks good to
Were did you get the MTU settings on the ATM0 ? and the BW ?
look strange to me ... BW setting maybe... Am not sure if this means anything
?? why this value ? it's 40 bytes lower than MTU from dialer0. IP header is only 20
were did you get the bitrate setting ?
were did you get the MTU ? (me thinks it defaul for PPPoATM) i would set to same size as eth0 issue is what size it must be ...
were in the world are these connection provided ? the different ISP's/providers have different implementations. Did you use CRWS to config the routerss ? It has a neat GUI which takes care of all these settings acording to provider etc.
