SSH Cisco ASA5505
Mar 14, 2008 4 Replies
Jump to replies (4)
I have a new ASA5505 that I am using in transparent firewall mode.
I can't figure out how to enable SSH and use it remotely?
Any advice is appreciated!
Thanks!
First, generate your public/private keys with: crypto key generate rsa modulus Second, enable ssh from the ip address that you wante to manage the ASS from. ssh outside
The ip address of the BVI is the management ip address.
Doan
I have tried these steps and they only work on the inside interface. I am still not able to connect from the outside interface.
I even tried
ssh 0.0.0.0 0.0.0.0 outside
and set a password.
am i missing something?
Do you have something upstream that may be blocking ssh packets?
Do you have an access-list on the outside interface? Check to see if you are allowing ssh in.
Doan
