Sh Run Question
Jul 27, 2006 4 Replies
Jump to replies (4)
How can I at Cisco Router on "non-Enable mode (router >)" can display Show Run or Show Interface??
You'd have to change the security level associated with those commands.
Allowing "show run" without further authentication would usually be considered a security mistake, since show run can reveal passwords that the person executing the command might not already have known.
"Walter Roberson" a écrit dans le message de news:8%5yg.250355$IK3.160800@pd7tw1no...
Juste to understand the procedure. Can you please post exemple how it possible to do it ?
Thanks a lot Best Regards
Rahan
"Walter Roberson" a écrit dans le message de news:Be7yg.244550$iF6.178330@pd7tw2no...
Thanks a lot !!
Rahan
