Does someone know how can i open 1 TCP port from my router to 1 computer that is connected to it?
Cisco 1700 router port forwarding
May 11, 2005
Most relevant reply
Config t..............ip nat inside source static tcp interface
some good documents on the subject:
and here are the notes I have put together so far:
================== to access the router ======================= access via a telnet session: telnet 10.10.10.1
access via service port console: connect the service port cable to com1 of windows PC programs - accessories - communications - hyper terminal set speed to 9600 press enter - get router prompt
================ privledged and configure mode ================== ( from the router prompt. either in telnet or console session. ) enable // enters privledged mode configure terminal // enters configure mode use ctrl-z to exit config mode
=================== commands ============================= enable // enter privlidged mode configure terminal // configure mode. show interface show ip nat translation
=================== debug commands =========================== enable term mon debug ip nat detailed
