Settinup 802.ix authentication with cisco 2950 and Micorsoft IAS
Jan 27, 2006 2 Replies
Settinup 802.ix authentication with cisco 2950 and Micorsoft IAS open original image
I have a project to stop rogue users form pluging onto my network. I have seen where cisco switches can do port authentication with a radius server. I would like to setup and IAS server on win2k3 as my radius server. Can anyone provide me with configuration guides to configure the switch as well as the IAS server? I would really appreciate the assistance.
PWM
You can find how to set up IAS for W2K (almost the same for W2K3) in the following page:
Regards,
AHG
Thanks for your reply. I tried it but i think that i am still doing something wrong.
Here is a copy of the dubug i did on my 802.1x SW_SPARE>en Password:
4d02h: AAA: parse name=tty0 idb type=-1 tty=-1 4d02h: AAA: name=tty0 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=0 channel=0 4d02h: AAA/MEMORY: create_user (0x80CC7D30) user='' ruser='' port='tty0' rem_addr='async' authen_type=ASCII service=LOGIN priv=1 4d02h: AAA/AUTHEN/START (1449486165): port='tty0' list='' action=LOGIN service=LOGIN 4d02h: AAA/AUTHEN/START (1449486165): console login - default to "no auth required" 4d02h: AAA/AUTHEN/START (1449486165): Method=NONE 4d02h: AAA/AUTHEN (1449486165): status = PASS 4d02h: AAA: parse name=tty0 idb type=-1 tty=-1 4d02h: AAA: name=tty0 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=0 channel=0 4d02h: AAA/MEMORY: create_user (0x80CCFC34) user='' ruser='' port='tty0' rem_addr='async' authen_type=ASCII service=ENABLE priv=15 4d02h: AAA/AUTHEN/START (3877385355): port='tty0' list='' action=LOGIN service=ENABLE 4d02h: AAA/AUTHEN/START (3877385355): console enable - default to enable password (if any) 4d02h: AAA/AUTHEN/START (3877385355): Method=ENABLE 4d02h: AAA/AUTHEN (3877385355): status = GETPASS SW_SPARE# 4d02h: AAA/AUTHEN/CONT (3877385355): continue_login (user='(undef)') 4d02h: AAA/AUTHEN (3877385355): status = GETPASS 4d02h: AAA/AUTHEN/CONT (3877385355): Method=ENABLE 4d02h: AAA/AUTHEN (3877385355): status = PASS 4d02h: AAA/MEMORY: free_user (0x80CCFC34) user='' ruser='' port='tty0' rem_addr='async' authen_type=ASCII service=ENABLE priv=15 SW_SPARE# 4d02h: AAA: parse name=tty1 idb type=-1 tty=-1 4d02h: AAA: name=tty1 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=1 channel=0 4d02h: AAA/MEMORY: create_user (0x80CDCAEC) user='' ruser='' port='tty1' rem_addr='172.17.12.100' authen_type=ASCII service=LOGIN priv=1 4d02h: AAA/AUTHEN/START (760582369): port='tty1' list='' action=LOGIN service=LOGIN 4d02h: AAA/AUTHEN/START (760582369): non console login - defaults to local database 4d02h: AAA/AUTHEN/START (760582369): Method=LOCAL 4d02h: AAA/AUTHEN ( SW_SPARE#760582369): status = GETUSER SW_SPARE# 4d02h: AAA/AUTHEN/CONT (760582369): continue_login (user='(undef)') 4d02h: AAA/AUTHEN (760582369): status = GETUSER 4d02h: AAA/AUTHEN/CONT (760582369): Method=LOCAL 4d02h: AAA/AUTHEN (760582369): status = GETPASS SW_SPARE# 4d02h: AAA/AUTHEN/CONT (760582369): continue_login (user='cisco') 4d02h: AAA/AUTHEN (760582369): status = GETPASS 4d02h: AAA/AUTHEN/CONT (760582369): Method=LOCAL 4d02h: AAA/AUTHEN (760582369): status = PASS SW_SPARE# 4d02h: AAA/MEMORY: free_user (0x80CDCAEC) user='cisco' ruser='' port='tty1' rem_addr='172.17.12.100' authen_type=ASCII service=LOGIN priv=1 SW_SPARE# 4d02h: dot1x-registry:** dot1x_vp_statechange: 4d02h: dot1x-ev:vlan 20 vp is removed on the interface FastEthernet0/24 4d02h: dot1x-ev:Now Processing: 20 link DOWN for FastEthernet0/24, accss_vlan = 20, oper_vlan = 20 4d02h: dot1x-registry:dot1x_port_modechange invoked on interface FastEthernet0/24 4d02h: dot1x-registry:dot1x_port_linkchange invoked on interface FastEthernet0/24 4d02h: dot1x-err:calling pm_idb_set_port_access_oper_vlanid with vlan=12 4d02h: dot1x-ev:supp_info=80CD3594 txWhen_timer SW_SPARE#=80CD35E4 quietWhile_timer=80CD35A4reAuthWhen_timer=80CD35C4 awhile_timer=80CD3604
4d02h: dot1x-ev:destroy supplicant block for 0000.0000.0000
4d02h: dot1x-ev:Enter function dot1x_aaa_acct_end 4d02h: dot1x-ev:Found a supplicant block for mac 0000.0000.0000 80CD3594
80CD3594
4d02h: dot1x-ev:dot1x_port_cleanup_author: cleanup author on interface FastEthernet0/24
4d02h: dot1x-ev:dot1x_post_message_to_auth_sm: cleanup author from int SW_SPARE#erface FastEthernet0/24 4d02h: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/24, changed state to down 4d02h: dot1x-registry:dot1x_port_linkchange invoked on interface FastEthernet0/24 4d02h: dot1x-registry:dot1x_port_linkcomingup invoked on interface FastEthernet0/24 4d02h: dot1x-ev:dot1x_port_enable: set dot1x ask handler on interface FastEthernet0/24 4d02h: dot1x_auth Fa0/24: initial state auth_initialize has enter 4d02h: dot1x-sm:Fa0/24:0000.0000.0000:auth_initialize_enter cal SW_SPARE#led 4d02h: dot1x-ev:auth_initialize_enter:0000.0000.0000: Current ID=0
4d02h: dot1x_auth Fa0/24: during state auth_initialize, got event
0(cfg_auto) 4d02h: @@@ dot1x_auth Fa0/24: auth_initialize -> auth_disconnected 4d02h: dot1x-sm:Fa0/24:0000.0000.0000:auth_disconnected_enter_action called 4d02h: dot1x-sm: dot1x_update_port_status called with port_status = DOT1X_PORT_STATUS_UNAUTHORIZED 4d02h: dot1x-ev:dot1x_port_cleanup_author: cleanup author on interface FastEthernet0/24 4d02h: dot1x-ev:do SW_SPARE#t1x_update_port_status: Called with host_mode=0 state UNAUTHORIZED
4d02h: dot1x-ev:dot1x_update_port_status: using mac 0000.0000.0000 to send port to unauthorized on vlan 0
4d02h: dot1x-ev:dot1x_port_unauthorized: Host-mode=0 radius/guest vlan=0 on FastEthernet0/24
4d02h: dot1x-ev: GuestVlan configured=0
4d02h: dot1x-ev:supplicant 0000.0000.0000 is default
4d02h: dot1x-ev:supplicant 0000.0000.0000 is last
4d02h SW_SPARE#: dot1x-ev:Found a supplicant block for mac 0000.0000.0000
80CD3594
4d02h: dot1x-ev:0000.0000.0000 is now unauthorized on port FastEthernet0/24
4d02h: dot1x-ev:dot1x_port_cleanup_author: cleanup author on interface FastEthernet0/24 4d02h: dot1x-ev:Enter function dot1x_aaa_acct_end 4d02h: dot1x-ev:Found a supplicant block for mac 0000.0000.0000 80CD3594
80CD3594
4d02h: dot1x_auth Fa0/24: idle during state auth_disconnected
4d02 SW_SPARE#h: @@@ dot1x_auth Fa0/24: auth_disconnected -> auth_connecting 4d02h: dot1x-sm:Fa0/24:0000.0000.0000:auth_connecting_enter called 4d02h: dot1x_bend Fa0/24: initial state dot1x_bend_initialize has enter 4d02h: dot1x-sm:Dot1x Initialize State Entered 4d02h: dot1x_bend Fa0/24: initial state dot1x_bend_initialize has idle 4d02h: dot1x_bend Fa0/24: during state dot1x_bend_initialize, got event 16383(idle) 4d02h: @@@ dot1x_bend Fa0/24: dot1x_bend_initialize -> dot1x_bend_idle 4d02h: dot1x-sm:D SW_SPARE#ot1x Idle State Entered 4d02h: dot1x-ev:Created port supplicant block 0000.0000.0000 expected_id=0 current_id=0
4d02h: dot1x-ev:dot1x_init_sb_oper_info:Default port supplicant at memloc 80CD3594
4d02h: dot1x-ev:dot1x_post_message_to_auth_sm: cleanup author from interface FastEthernet0/24 4d02h: dot1x-ev: dot1x_post_message_to_auth_sm:0000.0000.0000: Sending TX_FAIL
4d02h: dot1x-ev:dot1x_post_message_to_auth_sm:0000.0000.0000: Current ID=1
4d02h: dot1x-ev:Transmitting an EAPOL frame on FastEt SW_SPARE#hernet0/24 4d02h: dot1x-packet:Tx EAP-Failure, id 0, ver 1, len 4 (Fa0/24) 4d02h: dot1x-registry:registry:dot1x_ether_macaddr called 4d02h: dot1x-packet:Tx sa=0014.695e.d598, da=0180.c200.0003, et 888E (Fa0/24) 4d02h: dot1x-ev:dot1x_post_message_to_auth_sm: cleanup author from interface FastEthernet0/24 4d02h: dot1x-ev:dot1x_post_message_to_auth_sm: Tx for req_id for supplicant 0000.0000.0000
4d02h: dot1x-ev:Transmitting an EAPOL frame on FastEthernet0/24
4d02h: dot1x-packet:Tx EAP-Request(Id), id SW_SPARE# 1, ver 1, len 5 (Fa0/24) 4d02h: dot1x-registry:registry:dot1x_ether_macaddr called 4d02h: dot1x-packet:Tx sa=0014.695e.d598, da=0180.c200.0003, et 888E (Fa0/24) SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# 4d02h: dot1x-registry:dot1x_port_linkchange invoked on interface FastEthernet0/24 4d02h: dot1x-ev:supp_info=80CD3594 txWhen_timer=80CD35E4 quietWhile_timer=80CD35A4reAuthWhen_timer=80CD35C4 awhile_timer=80CD3604
80CD3594
4d02h: dot1x-ev:dot1x_port_ SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE# SW_SPARE#cleanup_author: cleanup author on interface FastEthernet0/24
4d02h: dot1x-ev:dot1x_post_message_to_auth_sm: cleanup author from interface FastEthernet0/24 4d02h: dot1x-registry:dot1x_port_linkchange invoked on interface FastEthernet0/24 4d02h: dot1x-registry:dot1x_port_linkcomingup invoked on interface FastEthernet0/24 4d02h: dot1x-ev:dot1x_port_enable: set dot1x ask handler on interface FastEthernet0/24 4d02h: dot1x_auth Fa0/24: initial state auth_initialize has enter 4d02h: dot1x-sm:Fa0/24:0000 SW_SPARE#.0000.0000:auth_initialize_enter called 4d02h: dot1x-ev:auth_initialize_enter:0000.0000.0000: Current ID=0
0(cfg_auto) 4d02h: @@@ dot1x_auth Fa0/24: auth_initialize -> auth_disconnected 4d02h: dot1x-sm:Fa0/24:0000.0000.0000:auth_disconnected_enter_action called 4d02h: dot1x-sm: dot1x_update_port_status called with port_status = DOT1X_PORT_STATUS_UNAUTHORIZED 4d02h: dot1x-ev:dot1x_port_cleanup_author: cleanup author on interface SW_SPARE#FastEthernet0/24 4d02h: dot1x-ev:dot1x_update_port_status: Called with host_mode=0 state UNAUTHORIZED
4d02h: dot1x-ev:suppli SW_SPARE#cant 0000.0000.0000 is last
80CD3594
80CD3594
4d02h: dot1x_auth Fa0/24: idle SW_SPARE#during state auth_disconnected
4d02h: @@@ dot1x_auth Fa0/24: auth_disconnected -> auth_connecting 4d02h: dot1x-sm:Fa0/24:0000.0000.0000:auth_connecting_enter called 4d02h: dot1x_bend Fa0/24: initial state dot1x_bend_initialize has enter 4d02h: dot1x-sm:Dot1x Initialize State Entered 4d02h: dot1x_bend Fa0/24: initial state dot1x_bend_initialize has idle 4d02h: dot1x_bend Fa0/24: during state dot1x_bend_initialize, got event 16383(idle) 4d02h: @@@ dot1x_bend Fa0/24: dot1x_bend_initialize - SW_SPARE#> dot1x_bend_idle 4d02h: dot1x-sm:Dot1x Idle State Entered 4d02h: dot1x-ev:Created port supplicant block 0000.0000.0000 expected_id=0 current_id=0
4d02h: dot1x-ev:T SW_SPARE#ransmitting an EAPOL frame on FastEthernet0/24 4d02h: dot1x-packet:Tx EAP-Failure, id 0, ver 1, len 4 (Fa0/24) 4d02h: dot1x-registry:registry:dot1x_ether_macaddr called 4d02h: dot1x-packet:Tx sa=0014.695e.d598, da=0180.c200.0003, et 888E (Fa0/24) 4d02h: dot1x-ev:dot1x_post_message_to_auth_sm: cleanup author from interface FastEthernet0/24 4d02h: dot1x-ev:dot1x_post_message_to_auth_sm: Tx for req_id for supplicant 0000.0000.0000
4d02h: SW_SPARE# dot1x-packet:Tx EAP-Request(Id), id 1, ver 1, len 5 (Fa0/24) 4d02h: dot1x-registry:registry:dot1x_ether_macaddr called 4d02h: dot1x-packet:Tx sa=0014.695e.d598, da=0180.c200.0003, et 888E (Fa0/24) SW_SPARE# 4d02h: dot1x-sm:Fa0/24:0000.0000.0000:dot1x_process_txWhen_expire called 4d02h: dot1x_auth Fa0/24: during state auth_connecting, got event 18(txWhen_expire) 4d02h: @@@ dot1x_auth Fa0/24: auth_connecting -> auth_connecting 4d02h: dot1x-sm:Fa0/24:0000.0000.0000:auth_connecting_connecting_action called 4d02h: dot1x-ev:dot1x_post_message_to_auth_sm: Tx for req_id for supplicant 0000.0000.0000
4d02h: dot1x-packet:Tx EAP-Request(Id), i SW_SPARE#d 1, ver 1, len 5 (Fa0/24) 4d02h: dot1x-registry:registry:dot1x_ether_macaddr called 4d02h: dot1x-packet:Tx sa=0014.695e.d598, da=0180.c200.0003, et 888E (Fa0/24) SW_SPARE# 4d02h: dot1x-sm:Fa0/24:0000.0000.0000:dot1x_process_txWhen_expire called 4d02h: dot1x_auth Fa0/24: during state auth_connecting, got event 18(txWhen_expire) 4d02h: @@@ dot1x_auth Fa0/24: auth_connecting -> auth_connecting 4d02h: dot1x-sm:Fa0/24:0000.0000.0000:auth_connecting_connecting_action called 4d02h: dot1x-sm:dot1x_auth_connecting_action:0000.0000.0000 reauth_count=3 exceeded DOT1X_DEFAULT_REAUTH_MAX
4d02h: dot1x-ev:Default and only instance. evaluation for guest vlan move
4d02h: SW_SPARE#dot1x_auth Fa0/24: during state auth_connecting, got event 7(authSuccess) 4d02h: @@@ dot1x_auth Fa0/24: auth_connecting -> auth_authenticated 4d02h: dot1x-sm:Fa0/24:0000.0000.0000:auth_connecting_exit alled 4d02h: dot1x-sm:Fa0/24:0000.0000.0000:auth_authenticated_enter called 4d02h: dot1x-sm: dot1x_update_port_status called with port_status = DOT1X_PORT_STATUS_AUTHORIZED 4d02h: dot1x-ev:dot1x_update_port_status: using mac 0000.0000.0000 to send port to authorized
4d02h: dot1x-ev:dot1x_update_port_ SW_SPARE#status: using mac 0000.0000.0000 to send port to authorized
4d02h: dot1x-ev:dot1x_port_authorized:supplicant 0000.0000.0000 is first, old vlan 1, new vlan 20
4d02h: dot1x-ev:dot1x_port_authorized: Host-mode=0 radius/guest vlan=20
4d02h: dot1x-ev: GuestVlan configured=1
4d02h: dot1x-registry:** dot1x_vp_statechange: 4d02h: dot1x-ev:vlan 20 vp is added on the interface FastEthernet0/24 4d02h: dot1x-registry:dot1x_port_ SW_SPARE#modechange invoked on interface FastEthernet0/24 4d02h: dot1x-ev:dot1x_port_authorized: clearing HA table from vlan 1
4d02h: dot1x-ev:dot1x_update_port_status:0000.0000.0000: Current ID=1
4d02h: dot1x-ev:Transmitting an EAPOL frame on FastEthernet0/24 4d02h: dot1x-packet:Tx EAP-Success, id 1, ver 1, len 4 (Fa0/24) 4d02h: dot1x-registry:registry:dot1x_ether_macaddr called 4d02h: dot1x-packet:Tx sa=0014.695e.d598, da=0180.c200.0003, et 888E (Fa0/24) 4d02h: dot1x-ev:Found a supplicant block for mac SW_SPARE# 0000.0000.0000 80CD3594
4d02h: dot1x-ev:0000.0000.0000 is now authorized on port FastEthernet0/24
4d02h: dot1x-ev:Searching DHCP snooping binding table for 0000.0000.0000/20 4d02h: dot1x-ev:No binding found 4d02h: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/24, changed state to up SW_SPARE#
Can you tell me what is going on here? I do not see any enteries in my IAS logs? What am i doing wrong.
PWM
