Catalyst 3550 and IAS authorization
Mar 31, 2006 21 Replies
Jump to replies (21)
Hi.
I've got In my network environment Cisco Catalyst 3550 SMI. I set it to use Radius authorization in IAS on Windows 2003. This Cisco device and IAS Server are in diffrent VLANs (diffrent subnets) but they can ping each other (routing between VLANs are working). IAS is confiured properly but sometimes (not always) I cannot login to this switch (log from IAS is OK - user which I use was accepted by rules configured on IAS) and after putting password and for a while I have information: % Backup authentication and login is not possible (I try to login from host which is in the same VLAN as this switch). In the same time, when I try to login form host, which is in the same VLAN as IAS Server, everything goes OK. Does anybody know what can be wrong??
Regards Slawek
  1. Post the IOS version in use and a sanitized switch config
  1. Capture the AAA debugging output for a succesful authentication from the problem VLAN;
debug radius debug debug aaa authentication
  1. When the problem occurs, again capture using the same commands and compare to see if the auth packets are being sent to IAS server and if the switch receives a response.
Cisco IOS version: IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(8)EA1c, RELEASE SOFTWARE (fc1)
a part of config:
aaa new-model aaa group server radius efls server xxx.xxx.xxx.xxx auth-port 1812 acct-port 1813 ! aaa authentication login efls group radius aaa authorization exec efls group radius aaa authorization network efls group radius enable secret 5 $1$HR5N$GV533w2f1RgLJal9Mjvos. enable password 7 1410000A02 ! radius-server host xxx.xxx.xxx.xxx auth-port 1812 acct-port 1813 key eflservice radius-server retransmit 3 ! line vty 0 4 password 7 15020A545C3D24362C login authentication efls line vty 5 15 password 7 15020A545C3D24362C login authentication efls
OK. I switched it on
Now I have access, so cannot notice what's wrong in log but I'll try some time later and mayby findout what is going on.
Thanks for advise Slawek
The idea is to capture the debug of the command now that it is working.
So turn on the debugs, login in, turn -off the debugs and post here teh debug output here
Also configure "logging buffer 10000 debug"
OK. Here is log from success login: .Mar 31 14:42:01: AAA/AUTHEN/CONT (2107571542): continue_login (user='(undef)') .Mar 31 14:42:01: AAA/AUTHEN (2107571542): status = GETUSER .Mar 31 14:42:01: AAA/AUTHEN (2107571542): Method=radius (radius) .Mar 31 14:42:01: AAA/AUTHEN (2107571542): status = GETPASS .Mar 31 14:42:04: AAA/AUTHEN/CONT (2107571542): continue_login (user='slabr') .Mar 31 14:42:04: AAA/AUTHEN (2107571542): status = GETPASS .Mar 31 14:42:04: AAA/AUTHEN (2107571542): Method=radius (radius) .Mar 31 14:42:04: RADIUS: ustruct sharecount=1 .Mar 31 14:42:04: RADIUS: Initial Transmit tty1 id 35 10.10.10.189:1812, Access- Request, len 74 .Mar 31 14:42:04: Attribute 4 6 0A0A06FA .Mar 31 14:42:04: Attribute 5 6 00000001 .Mar 31 14:42:04: Attribute 61 6 00000005 .Mar 31 14:42:04: Attribute 1 7 736C6162 .Mar 31 14:42:04: Attribute 31 11 31302E31 .Mar 31 14:42:04: Attribute 2 18 A2FE0EB9 .Mar 31 14:42:04: RADIUS: Received from id 35 10.10.10.189:1812, Access-Accept, len 64 .Mar 31 14:42:04: Attribute 7 6 00000001 .Mar 31 14:42:04: Attribute 6 6 00000002 .Mar 31 14:42:04: Attribute 25 32 3BB004C5 .Mar 31 14:42:04: RADIUS: saved authorization data for user E1980C at 861D48 .Mar 31 14:42:04: AAA/AUTHEN (2107571542): status = PASS
and here is when the lohin fails: .Mar 31 14:41:11: RADIUS: Tried all servers. .Mar 31 14:41:11: RADIUS: No response for id 33 .Mar 31 14:41:11: RADIUS: No response from server .Mar 31 14:41:11: AAA/AUTHEN (3799657483): status = ERROR .Mar 31 14:41:11: AAA/AUTHEN/START (3707451166): port='tty1' list='' action=LOGI N service=LOGIN .Mar 31 14:41:11: AAA/AUTHEN/START (3707451166): Restart .Mar 31 14:41:11: AAA/AUTHEN/START (3707451166): no methods left to try .Mar 31 14:41:11: AAA/AUTHEN (3707451166): status = ERROR .Mar 31 14:41:11: AAA/AUTHEN/START (3707451166): failed to authenticate .Mar 31 14:41:13: AAA/MEMORY: free_user (0x861D48) user='slabr' ruser='' port='t ty1' rem_addr='10.10.6.1' authen_type=ASCII service=LOGIN priv=1 .Mar 31 14:41:13: AAA: parse name=tty1 idb type=-1 tty=-1 .Mar 31 14:41:13: AAA: name=tty1 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port =1 channel=0 .Mar 31 14:41:13: AAA/MEMORY: create_user (0xE1980C) user='' ruser='' port='tty1 ' rem_addr='10.10.6.1' authen_type=ASCII service=LOGIN priv=1 .Mar 31 14:41:13: AAA/AUTHEN/START (1941398153): port='tty1' list='efls' action= LOGIN service=LOGIN .Mar 31 14:41:13: AAA/AUTHEN/START (1941398153): found list efls .Mar 31 14:41:13: AAA/AUTHEN/START (1941398153): Method=radius (radius) .Mar 31 14:41:13: AAA/AUTHEN (1941398153): status = GETUSER .Mar 31 14:41:16: AAA: parse name=tty2 idb type=-1 tty=-1 .Mar 31 14:41:16: AAA: name=tty2 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port =2 channel=0 .Mar 31 14:41:16: AAA/MEMORY: create_user (0xE1A220) user='' ruser='' port='tty2 ' rem_addr='10.10.10.186' authen_type=ASCII service=LOGIN priv=1 .Mar 31 14:41:16: AAA/AUTHEN/START (47063112): port='tty2' list='efls' action=LO GIN service=LOGIN .Mar 31 14:41:16: AAA/AUTHEN/START (47063112): found list efls .Mar 31 14:41:16: AAA/AUTHEN/START (47063112): Method=radius (radius) .Mar 31 14:41:16: AAA/AUTHEN (47063112): status = GETUSER .Mar 31 14:41:17: AAA/AUTHEN/CONT (47063112): continue_login (user='(undef)') .Mar 31 14:41:17: AAA/AUTHEN (47063112): status = GETUSER .Mar 31 14:41:17: AAA/AUTHEN (47063112): Method=radius (radius) .Mar 31 14:41:17: AAA/AUTHEN (47063112): status = GETPASS .Mar 31 14:41:20: AAA/AUTHEN/CONT (47063112): continue_login (user='slabr') .Mar 31 14:41:20: AAA/AUTHEN (47063112): status = GETPASS .Mar 31 14:41:20: AAA/AUTHEN (47063112): Method=radius (radius)
I don't know if it is all, because I increase looging buffer after success login. But one more thing. I've noticed, that when I first tried login from my host (the same VLAN as switch) - login fail, then login from host with the same VLAN as IAS Server - login success and after that I can login from my host.
The authentication failed becuase the switch did not get a response.
Put a sniffer (Ethereal) between the switch and the IAS server to confirm that this is the case. You should see a packet go out to the IAS server and then see no reply packet. If that is the case then the problem is on the IAS server
RADIUS uses UDP port 1812 by default ( or the port configured in teh IOS config)
Does the IAS server have a default gateway configured ?
You could also try configuring
ip radius source-interface
to see if that makes nay difference
Also the image you are using 12.1(8)EA1c is quite dated.
Suggest upgrading to a new image like 12.1(22)EA7
U¿ytkownik "Merv" napisa³ w wiadomo¶ci news: snipped-for-privacy@u72g2000cwu.googlegroups.com...
IAS Server has default gateway and if I try login just from IAS Server it always has success. And I was wondering, why I can login from my host after I login from host which is in the same VLAN as IAS Server? Maybe ip radius source-interface command should help... Now I set this command and see if it helps. But to check it out, I need some time.
U¿ytkownik "Merv" napisa³ w wiadomo¶ci news: snipped-for-privacy@e56g2000cwe.googlegroups.com...
I realize, that my IOS is pretty old. But I have to buy Cisco contract for new software and I don't know if my boss give me money for this...
  1. can you post santized config
  1. post output of extended ping using a) the source-interface of the vlan that the ISA server is on b) the source-interface of the problem vlan
Sorry, but I didn't understand "santized" word. Can you explain, what you mean??
Sorry for lame question but what's the "extended ping"?
here is an example of using extended ping that allow you to slect the source interface or source IP address instead of the router slecting it.
#ping Protocol [ipv4]: Target IP address: 3.3.3.3 Repeat count [5]: Datagram size [100]: Timeout in seconds [2]: Extended commands? [no]: yes Source address or interface: 12.15.1.1 Type of service [0]: Set DF bit in IP header? [no]: Validate reply data? [no]: Data pattern [0xABCD]: Loose, Strict, Record, Timestamp, Verbose[none]: Sweep range of sizes? [no]: Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 3.3.3.3, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Well, on this switch I have only one interface (routing between VLANs I have on other L3 device) and only one IP adress. My host is in VLAN6 (just like this switch) and IAS Server is in VLAN7. Now I have noticed that host from VLAN5 has no problem to telnet to this switch like IAS Server. It seems that only hosts from VLAN6 has problems to telnet this switch (I tried to login from other host which is in VLAN6 too, and telent was not possible). Any other suggestions??
Please connect to the 3550 switch (what is hostname) of the problem
3350 .
Perform an extended ping to the IAS server using the source IP address that is configured on the 3350switch.
Post extended ping results here
OK. Here you are: switch#ping Protocol [ip]: Target IP address: 10.10.10.189 Repeat count [5]: Datagram size [100]: Timeout in seconds [2]: Extended commands [n]: y Source address or interface: 10.10.6.250 Type of service [0]: Set DF bit in IP header? [no]: Validate reply data? [no]: Data pattern [0xABCD]: Loose, Strict, Record, Timestamp, Verbose[none]: Sweep range of sizes [n]: Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 10.10.10.189, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms switch#
Now post a traceroute ffrom 3350 to IAS server and a traceroute from IAS server to the 3550 (10.10.6.250)
Traceroute from switch to IAS Server: switch#traceroute 10.10.10.189
Type escape sequence to abort. Tracing the route to 10.10.10.189
1 10.10.6.253 0 msec 40 msec 24 msec 2 10.10.10.189 0 msec 0 msec 4 msec switch#
Traceroute from IAS Server to switch:
tracert 10.10.6.250
1 1 ms 1 ms 1 ms 10.10.10.238 2
telnetting to the switch) , can you reliably authenticate to the IAS server ?
Yes they can. Users on that switch are in VLAN2.
