new 6509 "Gigabit Ethernet x/x not a switching port"
Nov 14, 2005 4 Replies
Jump to replies (4)
Hi all, Need a bit of you expert advise on the 6509 I have just got my mits on. First of all, I have connection via the console port on the sup720-3b, even though the set interface sc0 x.x.x.x x.x.x.x just give me an error. I cannot connect to the router via the switch console 15 command. I assume that i am runnign in NATIVE mode as the "set" commands seem to be non-existant.
I thought i would push on and get some vLans set up etc to see how far we could get. When I try to put an intyerface in to a vLan
switchport access vLan x I get the "Gigabit Ethernet x/x not a switching port". Not be an expert at all here, am i running in Layer2 mode? How to I get it Layer3? I did not have this problem witht the 6519 we have.
Please help a know nothing IT guy. Thanks
Turn the port into a layer 2 port by:
config t int gi x/x switchport switchport access vlan y no shut
Then you create a layer 3 vlan interface
int vlan y ip add a.a.a.a b.b.b.b
Thanks Rex,
In my rush to get this done completly forgot to add the first plain "swithport" command. J
You need to enter switchport like this: SWAITC6513(config)#Interface fa4/1 SWAITC6513(config-if)#switchport SWAITC6513(config-if)#switchport access VLAN 21
The switchport is enabled by the first entry of the command "switchport" by itself.
thejayman wrote:
