Routing between VPN road warrior clients
Jun 29, 2006 3 Replies
Jump to replies (3)
A quick query about something that's causing a few problems at work.
We're using a Cisco router (IOS) so that people can connect to our network using the Cisco VPN client (on Windows).
Is it usually a problem to route between two hosts both connected using the Cisco VPN client?
It doesn't work here, and, from the research I've done, I suspect it's because the traffic from one VPN client arrives on the same interface that it needs to be routed onto.
But, I didn't find as much written about this as I would've expected if this was a common problem rather than just a problem with our specific network setup.
Any ideas, input, tips, etc ... much appreciated.
Cheers, David
[via an IOS router]
That would be a problem for PIX 6, but is possible using IOS, I understand. But I've never had to configure it.
-possibly- the following document would be of use:
Walter, thanks for the reply.
I'll have a read of that document you linked to, and keep investigating.
- David
As others have said, this is a feature in the PIX, but on a router it should work. I'm fairly certain you would need to have something in the config to stop the traffic. How about a config?
