atm0 going down every five minutes (DSL: Defect: LOS LOF LCDi: retraining)
Jun 29, 2006 1 Replies
Sorry to re-submit the question, however, I got somewhat further. Our c836 router loses connection every five minutes. The line is ok, other modems work fine. Our provider can see no problem. Can this have something to do with my config? At the moment it is still very simple, and I have never encountered a similar problem with the same provider.
Has anyone ever seen a similar problem?
Thanks in advance!
Pjn
The log:
Jun 29 14:33:51.750: DSL: Defect: LOS LOF LCDi: retraining Jun 29 14:33:51.750: DSL: Received response: 0x41 Jun 29 14:33:52.710: c820_atm_check_linkstate_periodic: PHY line is going down Jun 29 14:33:52.710: Shutting down ATM0... Jun 29 14:33:52.710: ATM0 c820_atm_shutdown: state=0 Jun 29 14:33:52.710: pquicc_sar_stop... Jun 29 14:33:52.710: c820_atm_stop_receive... Jun 29 14:33:52.966: pquicc_sar_rx_disable... Jun 29 14:33:52.966: Disable TX Cav .... Jun 29 14:33:52.966: Disable RX Cav .... Jun 29 14:33:52.966: Disable PD[15] and PD[14] .... Jun 29 14:33:52.970: c820_reset_vc: conid = 0 Jun 29 14:33:52.970: c820_reset_vc: conid = 3 Jun 29 14:33:52.970: Resetting ATM0
Firmware info:
Cisco IOS Software, C836 Software (C836-K9O3Y6-M), Version 12.3(8)T11, RELEASE S OFTWARE (fc1) Technical Support:
(c) 1986-2005 by Cisco Systems, Inc. Compiled Wed 10-Aug-05 20:25 by dchih
ROM: System Bootstrap, Version 12.2(11r)YV3, RELEASE SOFTWARE (fc2)
gw2 uptime is 2 hours, 52 minutes System returned to ROM by power-on System restarted at 11:48:51 UTC Thu Jun 29 2006 System image file is "flash:c836-k9o3y6-mz.123-8.T11.bin"
Running config:
! ! Last configuration change at 13:07:35 UTC Thu Jun 29 2006 by admin ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname c836 ! boot-start-marker boot-end-marker ! logging buffered 10000 debugging no logging console ! no aaa new-model ip subnet-zero ! ! ip ips po max-events 100 no ftp-server write-enable ! ! username admin privilege 15 secret 5 ! ! bridge irb ! ! interface Ethernet0 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-Ethernet 10/100$ ip address 192.168.20.1 255.255.255.0 ip nat inside ! interface BRI0 no ip address shutdown ! interface ATM0 no ip address no ip route-cache no ip mroute-cache no atm ilmi-keepalive dsl operating-mode auto dsl enable-training-log bridge-group 1 bridge-group 1 spanning-disabled pvc auto 0/34 encapsulation aal5snap ! ! interface FastEthernet1 no ip address duplex auto speed auto ! interface FastEthernet2 no ip address duplex auto speed auto ! interface FastEthernet3 no ip address duplex auto speed auto ! interface FastEthernet4 no ip address duplex auto speed auto ! interface BVI1 mac-address 000f.fe1e.f0a5 ip address dhcp ip nat outside ! ip classless ip route 0.0.0.0 0.0.0.0 BVI1 no ip http server ip nat inside source list 1 interface BVI1 overload ! ! access-list 1 permit 192.0.0.0 0.255.255.255 ! control-plane ! bridge 1 protocol ieee bridge 1 route ip ! line con 0 login local no modem enable line aux 0 line vty 0 4 privilege level 15 login local transport input telnet ssh ! scheduler max-task-time 5000 ! end
The problem is that the line distance is too short. Lines Sorry to re-submit the question, however, I got somewhat further. Our
