Check Point VPN Routing with SecuRemote and WatchGuard
May 23, 2005 1 Replies
We have a number of business partners that have IPSec tunnels using CP firewalls to our clients WG firewalls. I've not worked with the "SecuRemote" client/tool, so I can't speak for it specifically.
Key things to remember: both networks need to have different subnets - you can not have 192.168.10.0/24 on both sides.
In the WG, forming the tunnel is only part of the task, you need to create a rule that permits access from the remote network to the local network (best done as IP to IP to limit exposure).
Hi NG
Does anyone know if the Check Point VPN routing feature works when the satellite is a WatchGuard and you are using SecuRemote to reach it?
The central firewall is a CPT and provides a remote access VPN for SR. The client should now get routed through a new VPN to the internal network behind the WatchGuard.
TIA!
