Routing between ethernet interfaces on 1605r
Sep 18, 2006 2 Replies
Routing between ethernet interfaces on 1605r open original image
I am just wanting to configure a simple Lan to Lan router. I bought the
1605r because it was the cheapest on ebay. I am beginning to wonder if I should have bought a different router.
I have two networks that I want to be able to connect to each other. I don't need to get them to the internet I have an ISA box that does that. I would like to have the 192.168.1.0/24 on ethernet 0 and
192.168.2.0/24 on ethernet 1.
Running the QuickStart allows me to configure the appropriate IP's on each interface, but I think it does not enable IP routing between. I have just started playing with this today, here is the output of the show configuration command:
Using 756 out of 7506 bytes ! version 12.0 service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname 1605r-w2 ! enable secret ! username 1605r-w2 password ip subnet-zero no ip source-route ! ! ! interface Ethernet0 ip address 192.168.2.254 255.255.255.0 no ip directed-broadcast no ip proxy-arp ip rip send version 1 2 ip rip receive version 1 2 ! interface Ethernet1 ip address 192.168.1.150 255.255.255.0 no ip directed-broadcast no ip proxy-arp ip rip send version 1 2 ip rip receive version 1 2 ! router rip network 192.168.1.0 network 192.168.2.0 ! ip classless ! ! line con 0 exec-timeout 120 0 transport input none line vty 0 4 exec-timeout 0 0 login local ! end
Hi Jeff,
You may wish to investigate Cisco 1600 Series Router Documentation:
Sincerely,
Brad Reese BradReese.Com - Cisco Power Supply Headquarters
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Salary and Compensation Rates
Routing "between" the interfaces on the router is automatic once the interfaces have an address and are in the up/up state.
How are the hosts on the two networks configured?
Assume the ISA box is on 192.168.1.0/24 and it isn't running RIP.
The hosts on the 192.168.2.0/24 network need a default gateway of
192.168.2.254.
If you want all your hosts to have internet access the router needs a default route pointing at the ISA box.
! ip route 0.0.0.0 0.0.0.0 !
The ISA box also needs a specific route for the local network it isn't connected to.
route add 192.168.2.0 mask 255.255.255.0 192.168.1.150
