Outgoing PPTP traffic on a Cisco 1750
Jul 29, 2005 1 Replies
Outgoing PPTP traffic on a Cisco 1750 open original image
Ok, so I've just about got this Cisco 1750 doing what I need it to do. Today I found out that clients inside can't VPN out to an external Microsoft VPN PPTP server.
I CAN VPN out while on a box that has a static mapped address, so its something with the NAT pool with the clients. I'm trying to make sense of this, is there something not configured? What do I need to add?
here is my config:
Current configuration: ! version 12.0 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname internet ! enable password xxxxxxx ! ! memory-size iomem 25 ip subnet-zero ! ! interface Serial0 description internet connection bandwidth 1536 ip address 216.xxx.xx.62 255.255.255.252 no ip directed-broadcast ip nat outside encapsulation frame-relay IETF no fair-queue frame-relay map ip 216.xxx.xx.61 16 ! interface FastEthernet0 bandwidth 100000 ip address 192.168.1.250 255.255.255.0 no ip directed-broadcast ip nat inside full-duplex ! router rip version 2 network 192.168.1.0 ! ip nat pool nat-pool 216.xxx.xx.69 216.xxx.xx.70 netmask
255.255.255.248 ip nat inside source list 1 pool nat-pool overload ip nat inside source route-map internet interface Serial0 overload ip nat inside source route-map pptp pool pptppool ip nat inside source static 192.168.1.156 216.xxx.xx.68 ip nat inside source static 192.168.1.211 216.xxx.xx.67 ip nat inside source static 192.168.1.208 216.xxx.xx.66 ip nat inside source static 192.168.1.206 216.xxx.xx.65 ip classless ip route 0.0.0.0 0.0.0.0 216.xxx.xx.61 ip route 10.1.10.0 255.255.255.0 192.168.1.254 ip route 10.2.10.0 255.255.255.0 192.168.1.254 ip route 10.5.10.0 255.255.255.0 192.168.1.254 ip route 10.6.10.0 255.255.255.0 192.168.1.254 ip route 10.7.10.0 255.255.255.0 192.168.1.254 ip route 10.8.10.0 255.255.255.0 192.168.1.254 ip route 10.9.10.0 255.255.255.0 192.168.1.254 ip route 10.254.10.0 255.255.255.0 192.168.1.254 ip route 192.168.2.0 255.255.255.0 192.168.1.254 ip route 192.168.3.0 255.255.255.0 192.168.1.254 ip route 192.168.4.0 255.255.255.0 192.168.1.254 ip route 192.168.7.0 255.255.255.0 192.168.1.254 ip route 192.168.48.0 255.255.255.0 192.168.1.253 no ip http server ! access-list 1 permit 192.168.0.0 0.0.255.255 ! line con 0 exec-timeout 0 0 transport input none line aux 0 line vty 0 4 password xxxxx login ! end
What version IOS?
See
You need at least version 12.1(4)T to do PPTP over an "overload" connection. One to one will work fine in older IOS.
