rommon question
Apr 14, 2005 5 Replies
Jump to replies (5)
I have a router 3600 which stopped with rommon 1> prompt, I rebooted a couple of times didnt help. Does any one know what is wrong with that? Thanks in advance.
Please look at:
regards,
Chad
I think the problem is that I have an image with no .bin extension, so it cannot load it. the IOS is 11.1 and I even dont have tftpdnld command to load a new version of IOS. Is there anyway to rename the image or download other image to flash?
Thanks-Rob
There may be a rename command after you run the help_init and load_helper commands. There is always the XModem way of uploading a new image. Another way may be to type boot and the exact name of the file, even without the .bin it should load. Without the .bin it will not load by it's self I don't think. boot flash:c2600-i-mz.122-10b
The previous post linked to a page that covered all of this information also. It might help if you do some research and make sure your having the problem you think you are.
Mr.G
I already tried with exact name and no extention, didnt work! Rob
Rob schrieb:
Hi Rob,
another solution to download an image to a router is the xmodem download.
Please read Cisco's documentions to xmodem, take a lot of coffee and time and make the xmodem transfer.
Greeting
Gerd
