Cisco 827-4V update Rommon and IOS HELP needed
Apr 25, 2005 0 Replies
Hi all,
I bought a used Cisco 827-4V for home use, just to try to play with IOS.
Unfortunately, I played too much and I have involuntary delete the flash with the IOS image 12.1.
I had, from a friend that has the same router, the IOS 12.2 (c820-v6y6-mz.122-13.T.bin), I have followed all the steps to upload via xmodem the firmware to router in Rommon and then used tftp to upload the IOS image to the Flash, everything went ok.
I have setup the startup-config with the "system boot flash c820-v6y6-mz.122-13.T.bin" but, unfortunately, when I try to reload I am back to Rommon mode again.
Somewhere I found I had to update the Rommon before upgrading to verision
12.2 from 12.1, so I have update Rommon with C820_RM_ALT.srec.122-4r.XM4.
Again, if I try to reload I am back in Rommon mode.
Please, Help me if you can!!
Thanks to all in advance, Francesco
