Removing GBIC
Sep 26, 2005 7 Replies
Jump to replies (7)
Removing GBIC open original image
Hello, Is there a possibility to remove GBIC without turning off 3550 switch ? Is GBIC a hotplug device ?
Thanks, Allybee
No. If i remember correct, GBIC is not hot pluggable.
snipped-for-privacy@ge.com tried to tell us something, and all I got was:
Yes. GBICs are hotplug devices.
Do I need to type any command to stop/disable/prepare for remove, or just brutally remove it ?
You should just be able to unplug it. Obviously the interface will change state to 'down'.
In article , wrote: :Do I need to type any command to stop/disable/prepare for remove, or :just brutally remove it ?
Well, if it is the hasp variety, brutally removing it could leave you with a stuck GBIC.
If the current spanning tree is running through the port with the GBIC and if there is an alternate route being supressed, you might perhaps want the certainty gained by deliberately disabling the interface and ensuring that the new tree comes up.
On the other hand, if you can swap the GBICs in a few seconds, you might want to just go ahead -- saves rebuilding the spanning tree twice ;-)
It is not necessary to do anything other than pull out the GBIC when you are ready.
Hi Allybee,
You may find the Cisco GBIC Guide helpful:
Sincerely,
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272
I prefer wherever practicable to shut down interfaces prior to removal.
I feel that the "shutdown" code is likely to be simpler and more tested (field and otherwise) than the oops; it has gone code.
I have seen full resets on various hot swaps (in the Lab - 'cos that's where I have done most hot swaps.)
