Recording Call Manager Configuration
Aug 19, 2005 4 Replies
Jump to replies (4)
Sorry if this is a silly question, but I'm doing some work which is only peripherally connected with Call Manager for a customer, and I'd like to document the current call plan, CSS, Partitions &c.
Is there any easy way of dumping this data in human-readable form ?
jd
That is correct. The file will be .CSV format.
You can also dump the entire dial plan into the CallManager trace file by dialing **##*4 on a Cisco IP phone.
You can get some info by going to Route Plan -> Route Plan Report; then you can click on find or pick "View in File". All this is from my mind so it can be wrong.
HTH,
Thanks, chaps !
That's just what I needed to know...
jd
How (if at all) can you Import this csv back to call manager?
