Radius for Cisco 2924
Oct 26, 2006 2 Replies
Could someone tell me what IOS supports radius for a Cisco 2924 with the current hardware. The current IOS doesn't have the option to configure radius groups.
Thanks in advance,
Cisco Internetwork Operating System Software IOS (tm) C2900XL Software (C2900XL-H2S-M), Version 11.2(8.2)SA6, MAINTENANCE INT ERIM SOFTWARE Copyright (c) 1986-1999 by cisco Systems, Inc. Compiled Wed 23-Jun-99 17:48 by boba Image text-base: 0x00003000, data-base: 0x002432D0
ROM: Bootstrap program is C2900XL boot loader
FTLDFL_CAT2900_#1 uptime is 22 weeks, 15 hours, 39 minutes System restarted by power-on System image file is "flash:c2900XL-h2s-mz-112.8.2-SA6.bin", booted via
172.26.0 .38
cisco WS-C2924-XL (PowerPC403GA) processor (revision 0x11) with
8192K/1024K byte s of memory. Processor board ID 0x0E, with hardware revision 0x01 Last reset from power-on
Processor is running Enterprise Edition Software Cluster member switch capable
24 Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: 00:30:94:BB:F6:40 Motherboard assembly number: 73-3382-07 Power supply part number: 34-0834-01 Motherboard serial number: FAA03469FA6 Power supply serial number: NONE Model revision number: A0 Model number: WS-C2924-XL-EN System serial number: FAA0347G031 Configuration register is 0xF
You may wish to investigate the Cisco Feature Navigator:
Hope this helps.
since you have enterprise edition , just upgrade IOs to the latest version
