3750 and OSPF - Which IOS do I need
Apr 02, 2008 7 Replies
Most relevant reply
make
IP SERVICES or ADVANCED IP SERVICES
Hi I have a 3750 which doesn't support OSPF, here is the output of the sh ver command Can anyone tell me which IOS version and image supports OSPF?
Cheers, Scott
#sh ver Cisco Internetwork Operating System Software IOS (tm) C3750 Software (C3750-I9-M), Version 12.1(19)EA1d, RELEASE SOFTWARE (fc1) Copyright (c) 1986-2004 by cisco Systems, Inc. Compiled Mon 05-Apr-04 22:40 by antonino Image text-base: 0x00003000, data-base: 0x007CBC3C
ROM: Bootstrap program is C3750 boot loader BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(14r)EA1a, RELEASE SOFTWARE (fc1)
AFF-HO-CORE-SWITCH uptime is 14 weeks, 6 days, 15 hours, 41 minutes System returned to ROM by power-on System restarted at 18:59:25 WST Wed Dec 19 2007 System image file is "flash:/c3750-i9-mz.121-19.EA1d/c3750-i9-mz.
121-19.EA1d.bin"
cisco WS-C3750G-24T (PowerPC405) processor (revision F0) with 118776K/
12288K bytes of memory. Processor board ID CAT0853N09R Last reset from power-on
7 Virtual Ethernet/IEEE 802.3 interface(s)
72 Gigabit Ethernet/IEEE 802.3 interface(s) The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address : 00:13:19:14:27:80 Motherboard assembly number : 73-8046-07 Power supply part number : 341-0048-01 Motherboard serial number : CAT08520EZB Power supply serial number : DTH08491LSQ Model revision number : F0 Motherboard revision number : A0 Model number : WS-C3750G-24T-S System serial number : CAT0853N09R Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
  • 1 24 WS-C3750G-24T 12.1(19)EA1d C3750-I9-M 2 24 WS-C3750G-24T 12.1(19)EA1d C3750-I9-M 3 24 WS-C3750G-24T 12.1(19)EA1d C3750-I9-M
Switch 02
--------- Switch Uptime : 14 weeks, 6 days, 15 hours, 45 minutes Base ethernet MAC Address : 00:12:DA:8F:88:00 Motherboard assembly number : 73-8046-07 Power supply part number : 341-0048-01 Motherboard serial number : CAT08510L35 Power supply serial number : DTH08491L76 Model revision number : F0 Motherboard revision number : A0 Model number : WS-C3750G-24T-S System serial number : CAT0852X1LZ
Switch 03
--------- Switch Uptime : 14 weeks, 6 days, 15 hours, 43 minutes Base ethernet MAC Address : 00:0D:29:75:27:00 Motherboard assembly number : 73-8046-05 Power supply part number : 341-0048-01 Motherboard serial number : CAT072504UT Power supply serial number : LIT071800BN Model revision number : A0 Motherboard revision number : A0 Model number : WS-C3750G-24T-S System serial number : CAT0725R17Q
Configuration register is 0xF
IP SERVICES c3750-ipservicesk9-mz.122-44.SE1.bin or ADVANCED IP SERVICES c3750-advipservicesk9-mz.122-44.SE1.bin
You should use Cisco features navigator:
support: OSPF OSPF Forwarding Address Suppression in Translated Type-5 LSAs OSPF Inbound Filtering using Route Maps with a Distribute List OSPF Not-So-Stubby Areas (NSSA)
c3750-ipservicesk9-mz.122-44.SE1.b> IP SERVICES c3750-ipservicesk9-mz.122-44.SE1.bin
Cisco site wont let me download this file based on my current level of access - doh! All it will let me download is c3750-advipservicesk9-mz.122-40.SE.bin Will this suffice?
Scott
You should try the navigator. Ip services and advanced ip services supports OSPF (advanced ip services supports also ospf for ipv6). IP Base doesnt support OSPF.
Thanks for that link and it answers my question which yes c3750- advipservicesk9-mz.122-40.SE.bin supports OSPF and I have been able to successfully download this file, strange thou it wont let me download c3750-advipservicesk9-mz.122-44.SE1.bin thou
Cheers for everyones input
All "advipservices" support OSPF.
So the answer is yes.
Unless - 12.2(40)SE has some horrendous bug. In that case though it will have been most likely deferred and would not be available for download.
