3560 Enhanced - How do I know
Jul 30, 2007 5 Replies
Most relevant reply
Doug McIntyre
The URL above is messed up. I changed it to what I thought it should be (s/probriefducts/products/), and whoever gave it to you gave you the 1000' big picture. Not very helpful in this case.. 24-TS is part of a valid part #. You need the *complete* part number to tell if you…
How can I tell if a Cat 3560 is enhanced? I've heard that if it has an E after the IOS, however looking at the IOS there is an E, but like so 12.2(25)SEB4. But not sure if that qualifies for E???
THanks in advance.
according to Cisco docs, it is supposed to show up in the output of show version:
3560#show version Cisco Internetwork Operating System Software IOS (tm) C3560 Software (C3560-I5-M), Version 12.1(19)EA1c, RELEASE SOFTWARE (fc 2) Copyright (c) 1986-2004 by cisco Systems, Inc. Compiled Tue 03-Feb-04 05:56 by yenanh Image text-base: 0x00003000, data-base: 0x0091D404
ROM: Bootstrap program is C3560 boot loader BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.1(19r)EA1b, RELEASE SOFTWA RE (fc2)
3-8-03-CATS3560 uptime is 8 weeks, 4 days, 18 hours, 16 minutes System returned to ROM by power-on System image file is "flash:c3560-i5-mz.121-19.EA1c.bin"
cisco WS-C3560-24PS (PowerPC405) processor (revision D0) with 118776K/
12288K byt es of memory. Processor board ID CSG0802P0G4 Last reset from power-on Bridging software. 1 Virtual Ethernet/IEEE 802.3 interface(s) 24 FastEthernet/IEEE 802.3 interface(s) 2 Gigabit Ethernet/IEEE 802.3 interface(s) The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address : 00:0E:39:E9:32:80 Motherboard assembly number : 73-9299-01 Power supply part number : 341-0029-03 Motherboard serial number : CAT075108EK Power supply serial number : LIT074900K3 Model revision number : D0 Motherboard revision number : C0 Model number : WS-C3560-24PS-E
Merv has given u a right answer
For more refrence go through the below link, it will give u idea about the CISCO IOS Software
ducts/sw/iosswrel/ps1818/ products_tech_note09186a00800b6e23.shtml
So looking at this, appears that I do not have the extended version? I have the 24-TS and IOS is 12.2(25)SEB4. Is that correct?
Cisco IOS Software, C3560 Software (C3560-IPSERVICES-M), Version
12.2(25)SEB4, R ELEASE SOFTWARE (fc1) Copyright (c) 1986-2005 by Cisco Systems, Inc. Compiled Tue 30-Aug-05 14:19 by yenanh
ROM: Bootstrap program is C3560 boot loader BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWAR E (fc4)
3560_Switch uptime is 2 days, 18 hours, 11 minutes System returned to ROM by power-on System image file is "flash:c3560-ipservices-mz. 122-25.SEB4/c3560-ipservices-mz. 122-25.SEB4.bin"
cisco WS-C3560-24TS (PowerPC405) processor (revision D0) with 118784K/
12280K byt es of memory. Processor board ID CAT1022N6CY
24-TS is part of a valid part #. You need the *complete* part number to tell if you have the enhanced version (-E) or not (-S). 12.2(25)SEB4 is a version of IOS. There are both standard and enhanced versions of 12.2(25)SEB4 out.. Again, you need the *complete* filename to read off the feature codes.
Ah, here's something, you are running the IPServices feature set of IOS. Thats usually the enhanced version (but not Advanced version). ipbase is the Standard image. ipservices is the enhanced version. advipservices is the Advanced version.
You aren't looking in to the right area of the 'show ver' for the full part #.
Go down lower. Where it has Base ethernet MAC address, assembly numbers, part numbers, serial numbers, etc.
But especially.. Model number : WS-C3560-24TS-E
This is an enhanced 3560-24TS of mine.
Thank much...I can't get to the device right now, but will be able to first thing in the morning...EST.
I didn't see the -E in the model number however. Thanks again:)
