project to configure Cisco Catalyst 6509
Apr 24, 2006 2 Replies
Hello Gurus,
I am a networking newbie. I would be working on a project with a few people to configure a Catalyst 6509 as a network backbone for a compnay. So far I have found out that it runs IOS version 12.2(17r)S2. Has a supervisor engine 720 module.
6724 SFP 24 port gigabit eth SFP module
6748 GE TX 48 port module
6704 -10 GE module
I was reading the software documentation which enlists all the commands.I will definately use that as a reference. But I need some basic information which is common while setting up a network backbone to get me started.I would really appreciate if you guys could get me started on this.
I hope you could guide me with this query.
Cheers, Ankit Parikh
This is supervisor firmware version, not the IOS. Type Show ver and put the results here.
Tell which port you connect to other switches and do you put host directly to backbone? Trunk? VTP Server? Routing? What IP address? VLANs?
IOS version selection - use a safe harbour release
Physical design considerations like slot assignments ( i.e card placement) - consider fiber cablerouting and copper cable routing. fiber is very dleicate so you need to protect it as much as possible.
Logical design considerations - IP routing, VLAN numbering, Trunking, Vlan pruning on trunks, Spanning Tree
suggestions: run switch in transparent mode and avoid VTP confiugre trunks in non-negotiable mode and avoid use of DTP use UDLD to detect uni-directional links use routed links whereever possible use NTP to ensure all switches have synced and accurate time
sample trunk config from working SUP720:
interface GigabitEthernet1/1 description trunk to xxxxx no ip address logging event link-status load-interval 30 switchport switchport trunk encapsulation dot1q switchport trunk allowed vlan switchport mode trunk switchport nonegotiate no shut
