Catalyst 6509
Oct 24, 2006 1 Replies
Hi, do you know if exist bug in 24 Sfp Module of Catalyst 6509? I upgraded it at the last Ios version but sometimes this module go offline, to return online I need to replace e reinsert it! Do you know if exist command to software-restart it? Regards
Hi Marco,
The WS-X6724-SFP module with Distributed Forwarding Card ( DFC3A ), that runs Cisco IOS Software Release 12.2(18)SXE1 reloads unexpectedly due to a memory allocation failure.
Before the reload, the available memory in the module is around 200k.
Cisco bug ID CSCei20107.
There is NO workaround.
This problem is fixed in Cisco IOS Software Releases 12.2(18)SXE4,
12.2(18)SXF and later versions.
To resolve this problem, upgrade the Cisco IOS Software on the switch to the latest maintenance release, which can be downloaded from:
Cisco Catalyst 6500/6000 Cisco IOS System Software
Hope this helps.
