Catalyst 6509 Recursive Routing
Apr 10, 2005 1 Replies
Catalyst 6509 Recursive Routing open original image
  1. I have a plan to use Recursive Routing.
  1. My Network exist Local and remote, Inter area is ISP
  2. How to do recursive routing at catalyst 6509(native, Sup2)
  1. I did not find IOS and that is true apadtaion to recursve routing CAT6.
Thank
Not sure I understand your whole effort here...but when you speak of recursive routing, it generally means:
For any nondirectly-connected route in the routing table whose next hop IP address is not a directly-connected interface of the router, the routing algorithm looks recursively into the routing table until it finds a directly-connected interface to which it can forward the packets.
so i use recursive routing in the example of I have an advertised route from a provider of which I do not understand (default) the next hop (outbound interface). I then put a static route for the recursive lookup to point (how to) get to the next hop.
Hope this was helpful.. snipped-for-privacy@gmail.com
