ATTN: Design Engineers. Require 100 remote site VPN solution.
Apr 24, 2006 1 Replies
Hello Design Engineers,
I need some help coming up with a solution for a 100 remote worker site to site VPN.
Sure I could just statically connect them all to the hub site, but I was hoping for a more scaleable solution.
Is there any way I could have the remote site address ranges allocated by the Hub site? I.e. as they come online, the hub site allocates them a /27 address space?
Is NAT the only way to achieve this?
Thanks in advanced.
Your Subject: implies that you have 100 remote sites. The above sentance implies that you have one remote site with ~100 hosts.
"Scaleable" isn't something one would normally consider if one is only doing something once.
That's sounding like you have multiple sites rather than one.
I suggest you search for Merv's recent mention in this group of DMVPN and another technology that I don't recall the name of.
