Removing old module config / Catalyst 6509
Jan 11, 2007 2 Replies
We have recently added and the removed a 16 port GBIC blade into a Catalyst 6509.
Even though the card is no longer present in the system the interfaces are still visible in the config. I presume this is in case the card is ever returned to the system.
My question is how can I remove this unnecessary config? The card is no longer displayed under "show module" but is still there under "show run"...
! interface GigabitEthernet3/1 no ip address shutdown ! interface GigabitEthernet3/2 no ip address shutdown ! interface GigabitEthernet3/3 no ip address shutdown
(config)# no interface range Gi3/1 Gi3/16 ?
Regards
fw
AFAIK the only way to get rid of that config now (in native IOS) is inserting another module in that slot or a reload. For now I suggest you just do a "default interface gi /1 - 16" and a shutdown on same to avoid surprises if someone ever inserts a similar module in the same slot.
There is a (almost undocumented) global command "module clear-config" which should be issued BEFORE removing the module. Using this command should cause most (but not all) traces of a module to disappear when you remove a module. I've never really used this command, a bit dangerous if you just want to replace a module and forgot this command was in the configuration.
In CatOS there is a "clear config " command if you're running CatOS only. If you're running hybrid that doesn't remove them from the IOS config.
luck,
Frans
