PPPoFR and Router IP's
Nov 30, 2007 2 Replies
I have a circuit that's PPPoFR that has a block of routed IP's. For the PPP session IP the ISP uses an internal private IP then routes the block to it. Now I have the first usable configured on a FE interface but if I don't have anything connected it the interface obviously goes down. What configuration can I use to keep that interface enabled even though nothing is plugged in? I tried keepalives but no luck.
thanks in advance...
Why use a physical interface at all? Use a loopback, will never go down.
