VPN 3030 and OSPF configuration
Apr 08, 2005 2 Replies
Current Configuration:
VPN_Concentrator_3030_Public_Interface -----> 6509 (vlan int 999) VPN_Concentrator_3030_Private_Interface ------> 6509 (vlan int 888)
We are not following Cisco's symantic of public, private and external interfaces suggested in documentation.
Private interface is only used for Managemnt.
5 groups are configured on Concentrator. Aggregate block is
172.31.0.0/24
Static route is installed on 6509. # ip route 172.31.0.0 255.255.255.0 PUBLIC_INTERFACE_OF_CONCENTRATOR
Everything works.
Desired Configuration:
----------------------- We would like to have OSPF between 6509 and Concentrator, instead of using static routes. Enabled OSPF on PUBLIC_INTERFACE_OF_CONCENTRATOR. Reverse Route Ijection: is setup properly and have
172.31.0.0/255.255.255.0 in hold down routes.
Problem:
-------- OSPF is up between 6509 and PUBLIC_INTERFACE_OF_CONCENTRATOR. Concentrator gets all the Routes from 6509. But, Concentrator is NOT feeding 172.31.0.0/24 routes in OSPF. Thus
6509 is NOT seeing 172.31.0.0/24 routes from Concentrator.
Any pointers would be appreciated.
Thanks.
Configuration | System | IP Routing | OSPF Configuration | System | IP Routing | OSPF Areas Configuration | Interfaces | Ethernet 2 -> OSPF Tab
I do have all params. configured. 'sh ip ospf nei' on 6509 give me Concentrator as ospf neighbour. Also VPN_Concentrator gets all the routes from 6509.
But, Concentrator is NOT able to feed ip block (used by groups defined on concentrator) into OSPF area.
Thanks.
