Frame-Relay and PPP Help
Apr 13, 2006 1 Replies
Frame-Relay and PPP Help open original image
Hello I am trying to prepare for my skills based assessment and have run into a snag. I am configuring 3 routers to simulate a Frame-Relay and PPP network, Frame-Relay is configured on ISP and Sydney routers while PPP is configured on both Sydney and Auckland routers. Pings work from Sydney to Auckland, ISP to Sydney, but NOT from Auckland to ISP. I have checked my configurations over the best I could and still cannot find the problem. If anyone has any ideas please let me know. Thank you in advance for the help.
some output ommited
NET ! interface Serial0 bandwidth 64 ip address 192.168.1.5 255.255.255.252 encapsulation frame-relay IETF no keepalive clockrate 64000 frame-relay map ip 192.168.1.6 101 no frame-relay inverse-arp frame-relay lmi-type ansi ! router rip version 2 network 10.0.0.0 network 192.168.1.0 ! ip classless ip route 172.16.4.0 255.255.255.0 Serial0 ip route 172.16.15.0 255.255.255.0 Serial0 ip route 192.168.2.0 255.255.255.252 Serial0 no ip http server !
STJO ! interface Serial0 bandwidth 64 ip address 192.168.1.6 255.255.255.252 encapsulation frame-relay IETF no keepalive no fair-queue frame-relay map ip 192.168.1.5 101 no frame-relay inverse-arp frame-relay lmi-type ansi ! interface Serial1 ip address 192.168.2.1 255.255.255.252 encapsulation ppp clockrate 64000 ppp authentication chap ! router eigrp 1 redistribute static network 172.16.4.0 0.0.0.255 network 192.168.2.0 0.0.0.3 auto-summary ! router rip version 2 network 192.168.1.0 ! ip classless ip route 0.0.0.0 0.0.0.0 Serial0 no ip http server !
BRANSON ! interface Serial0 ip address 192.168.2.2 255.255.255.252 encapsulation ppp ppp authentication chap ! ! router eigrp 1 network 172.16.15.0 0.0.0.255 network 192.168.2.0 0.0.0.3 auto-summary ip classless no ip http server !
You are running routing protocols that use multicast addresses for their operation but your frame relay maps are missing the broadcast keyword to allow that to work. Add the broadcast keyword to the frame relay map statements and see if that causes the failing pings to start working.
Cisco da Gama
