PIX PDM Certificate problem
Feb 19, 2006 3 Replies
Jump to replies (3)
PIX PDM Certificate problem open original image
I've sort of a problem, quite common but can't solve it :(
I've PIX which uses certficate/radius authentication, it talks to a W2k3 Enterprise CA, everything works fine, the pix get's and certficate and users who have a certificate to can make a connection to the PIX, BUT
when that works the PDM doesn't work anymore, when I clear the CA config in the pix, everything works again.
it looks like this thread, BUT, I use a enterprise CA
I think it's a very simpel problem, the certificate given by the W2k3 CA is not SSL compatible, which means that the PIX can't use that certificate for the webserver. How can I make change that, or how can I add that functionality to the certificate
btw, I can not use a standalone ca because of windows authentication!
anyone an idea!?!?!?!
Kind regards
Richard Kraal
Is the PIX date & time correct ?
If not use NTP to keep it current
see
Yes, works fine, server and pix use both NTP and clocks are up to date and in the right region!
nobody uses a pix with an (MS Win2k3) enterpise CA?
can't imagine :(
