PIX Logging
Oct 20, 2006 3 Replies
Jump to replies (3)
PIX Logging open original image
Does not matter what logging level I set the PIX does not log any messages.
Has anyone seen a PIX which will simply not log anything.
G
Hi Gary,
You may wish to investigate Cisco's Accessing and Monitoring PIX Firewall:
Hope this helps.
Brad Reese BradReese.Com - Refurbished Cisco PIX Firewall Guide
Sorry to say but PIX logs everything which it does.
Do setup Syslog Server
pix(config)#logging on pix(config)# logging device-id hostname | ipaddress if_name | string text pix(config)# logging message level
K
Gary wrote:
If you are using the PIX's graphical user interface (PIX Device Manager (PDM)) probably the following article may be helpful:
Configuring syslog on Cisco PIX
Michael
