Cisco Aironet 1200 multiple ssid
Oct 20, 2006 1 Replies
Cisco Aironet 1200 multiple ssid open original image
Hi, i am trying to get my aironet 1200 access point to show both ssids. I assigned two ssids, to two seperate VLANS. However i cant connect or see the networks on any wireless client (Windows XP. I can see when i set up one access point ssid and disable vlans under the http quick setup).
Using the CLI configure i type:
dot11 ssid public vlan 1 interface d0 ssid public exit
dot11 ssid private vlan 2 interface d0 ssid private exit
interface d0 mbssid exit
end
I havent set the guest-mode, do i need to do this? I cant get a good understanding from the docs so i didnt enable this.
Also, i presume once i enable multiple VLANS the Fast Ethernet 0 interface is turned into a dot1q trunk, and as such I will need to enable dot1q trunking on my connecting switch which goes into the access point?
Thanks in advance replies much appreciated,
Chris
Hi Chris,
You may wish to investigate Cisco's Configuring Multiple SSIDs:
Hope this helps.
