where is my NAT translations ?
Aug 01, 2005 2 Replies
rave
Hi DT, It woule be better if you can paste the debug output and also ip nat translation commands here.
My router has NAT set up and "debug ip nat" show a lot of NATted packets ( it is working now and currently about 50 users are going out to the Internet thru it ) , but "sh ip nat translations shows me me just an empty line.
#sh ip nat translations Pro Inside global Inside local Outside local Outside global
Any advicve is greatly appreciated.
DT
Hi DT,
Here is part of the "debug ip nat" output
002187: *Aug 2 00:14:32.845: NAT: TCP s=1755, d=28057->3988 002188: *Aug 2 00:14:32.845: NAT: s=38.113.221.12, d="my gateway"->192.168.249.225 [60684] 002189: *Aug 2 00:14:32.845: NAT: TCP s=3988->28057, d=1755 002190: *Aug 2 00:14:32.845: NAT: s=192.168.249.225->"my gateway", d=38.113.221.12 [39775] 002191: *Aug 2 00:14:32.853: NAT: TCP s=1755, d=28057->3988 002192: *Aug 2 00:14:32.853: NAT: s=38.113.221.12, d="my gateway"->192.168.249.225 [60683] 002193: *Aug 2 00:14:32.853: NAT: TCP s=3988->28057, d=1755 002194: *Aug 2 00:14:32.853: NAT: s=192.168.249.225->"my gateway", d=38.113.221.12 [39776] 002195: *Aug 2 00:14:33.497: NAT: TCP s=1755, d=28057->3988 002196: *Aug 2 00:14:33.497: NAT: s=38.113.221.12, d="my gateway"->192.168.249.225 [62925] 002197: *Aug 2 00:14:33.501: NAT: TCP s=3988->28057, d=1755 002198: *Aug 2 00:14:33.501: NAT: s=192.168.249.225->"my gateway", d=38.113.221.12 [39777] 002199: *Aug 2 00:14:33.505: NAT: TCP s=1755, d=28057->3988 002200: *Aug 2 00:14:33.509: NAT: s=38.113.221.12, d="my gateway"->192.168.249.225 [62924] 002201: *Aug 2 00:14:33.509: NAT: TCP s=3988->28057, d=1755 002202: *Aug 2 00:14:33.509: NAT: s=192.168.249.225->"my gateway", d=38.113.221.12 [39778] 002203: *Aug 2 00:14:34.145: NAT: TCP s=1755, d=28057->3988te 002204: *Aug 2 00:14:34.145: NAT: s=38.113.221.12, d="my gateway"->192.168.249.225 [65164] 002205: *Aug 2 00:14:34.145: NAT: TCP s=3988->28057, d=1755 002206: *Aug 2 00:14:34.145: NAT: s=192.168.249.225->"my gateway", d=38.113.221.12 [39779] 002207: *Aug 2 00:14:34.153: NAT: TCP s=1755, d=28057->3988 002208: *Aug 2 00:14:34.153: NAT: s=38.113.221.12, d="my gateway"->192.168.249.225 [65163] 002209: *Aug 2 00:14:34.153: NAT: TCP s=3988->28057, d=1755 002210: *Aug 2 00:14:34.153: NAT: s=192.168.249.225->"my gateway", d=38.113.221.12 [39780] 002211: *Aug 2 00:14:34.797: NAT: TCP s=1755, d=28057->3988
and the output of show ip nat translations is myhostname# sh ip nat translations Pro Inside global Inside local Outside local Outside global myhostname#
I use the new IP NAT command ( from 12.3.14T ) "ip nat enable" instead of "ip nat inside/outside"
DT
